I am a bit bummed I didn't try the 300lb springs on the fox shocks. I think that would have been the right path forward. Plus the Elkas were cheap and I was just lucky to get them
changing the stock to fox was a massive improvement, changing the springs was a more drastic improvement over the out of the box springs.
Edit: what works for AL/TN won’t work for desert.
Russ989
Russ989
22,645
147,291
For all of you guys with Ram pickups, ProClip makes a phone mount just for our trucks. I installed mine yesterday.
584A2679 98E6 4957 BA09 2F164BB17370
D9B81B3C D68D 4B53 BB40 A3021EEF991A
Keep hearing about how much better it is with springs.
I was actually pretty happy until recently. Added the rear faced a-arms and it feels better, more aggressive and sure footed with just people up front but got spongy with people in back to the point you had to lift when prior I didn’t. Was surprised to see that much bigger diff. I’ll try screwing down the rear, might just have to try new new springs
Mopower58
Mopower58
Unburdened by what has been!
88,233
755,288
Crystal Springs,Ms.
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
New springs are great. Im running 250 front and 275 rear. 300 would be better for heavy loads.
How does 275 handle weight? Trying to set it up somewhere in between. Problem we have is it’ll go from 2-5 people in one ride. Plus the cooler always. It sucks because right now it’s go time with just wife and I. I know it’ll loose some of that but hopeing not much.
Reactions: BWAF and Mudwing
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
For grown passengers and big cooler i think the 300 would do better. The 275 will let the tires make contact from time to time...especially when running hard. I usually dont have a real heavy load in mine. I would like to put the pin type spring adjusters on the rear shocks so i could add a little preload if i was running heavy without pulling the dam shock
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,231
Oshkosh, Wi
The pin type adjusters on the Elkas make preload adjustments so much easier than the fox shocks. At first I wasnt sure about that but after 1 adjustment I knew it was better
