P1000 Hard or soft? How do you like it?
Ladies and gents, what do you like better?
  • Hard
  • Soft
  • Whatever else you put on it…
Results are only viewable after voting.
Vikes79
Vikes79
SKOL!
11,684
113,328
South Dakota
  2. Talon X4 LV
IMO the Honda roof is actually the best hard roof there is for the Pioneer….you almost never hear a complaint about durability. They don’t rattle, and are easy to remove. It also provides a nice rub point for when your ROPS leans on a tree or ground.
It’s not a topic that is discussed much, as most just go with the Honda roof and have no regrets.
Jankyeye
Jankyeye
827
4,002
Tampa, Fl.
I have the Tusk aluminum roof, wanted to use it for strapping things down during hunting. It’s a bit heavy though, considering a soft mesh type roof for summers time.
HeadedOut
HeadedOut
172
1,200
Spokane Wa
I was thinking a soft top too but since this is our first sxs, wanted to see how much the hard top keeps the heavy branches and debris out. I was thinking soft top would be fine for service roads and groomed trails. I don’t see the wife getting into too much aggressive rock crawling. Lol
115,288
Keep in mind the soft top is a pita to get clean when it gets mud on it.
I had one for a few months some time ago when i first got the sxs. Hated that thing. Wished i had put my money to some sort of hard top at the time. There are some that like the soft top, but not too many.
HeadedOut
HeadedOut
172
1,200
Spokane Wa
Luckily enough my dad does leather work. Makes chaps and chinquideros for our rodeo and livestock buddies. He has a few big sewing machines that will work just fine. We have some leftover material when he made a bikini top for my cousins jeep. I don’t think it’ll be enough to stretch to the cage but there should only be a 1-2in gap all the way around.
115,288
Thought u were asking which one to buy? In that case, give it a try then. U have nothing to loose
StewB
StewB
720
3,340
I looked around a chose the Honda hardtop for my P1K5. Too expensive, but I think it's the best out there.
It covers the corners so rain doesn't dump in and the front points wrap down over the ROPS to help stop Pinyon Juniper branches from wedging in and ripping the top off.
It also sits up higher from the ROPS which gave me room to install mesh bag carriers underneath. I keep a lot of gear stowed away up under the roof, which lets me clean the machine without having to unpack everything.
HeadedOut
HeadedOut
172
1,200
Spokane Wa
Yes and no. I like inexpensive first off. And for mine since the roll bar is bent a hard top won’t quite fit. There are little plastic clips from the old hardtop, which were all snapped off when they wrecked.
Plus I just wanted everyone else’s opinion or pro/cons about what they have. Give me an idea of what to look for and what to put effort into first. Time is money muh man!
HeadedOut
HeadedOut
172
1,200
Spokane Wa
Damn. That’s a great idea. Stuff stored up high so a pressure washer makes the cleaning quick and easy.
JenElio
JenElio
72,982
664,827
Loxahatchee, florida
Given you have a bent cage now and all, I understand if you want just a temp top. But, when it comes time to put real money down, my vote goes to the OEM hard top. I know they've gotten more expensive like anything else, but top is worth its weight in gold. One of the best accessories I have on my rig
StewB
StewB
720
3,340
If I recall, there were some Bimini soft tops that should wrap over your bent cage. Good luck.
ODAMO
ODAMO
1,283
3,450
Ohio
If your of the ilk that time is money, then you really should fix the rops with your money first. A second roll over on a damaged rops might make you spend your time doing some sad stuff. I saw somebody have to get air lifted to the hospital because their roll bar caved in.
