P500 Has anyone trailered a 500 backwards with a soft back window?
83501Bill
14
27
idaho
Just wondering if I should remove it first. That could be a pain. I am going to load it in the back of my Tundra Crew cab, only a 5.5 foot bed. with ramps it will be at the end of the tailgate. I am worried that with the winch I may need to load it backwards. Has anyone had any experience with this?
Thanks
Bill
Thanks
Bill
Yes, when I get back off the road, I'll post a picture of the damage I did to the bed of my truck below the back window. Back your P-5 in, the tires are the first thing to make contact with the bed, ratchet it down tight and you'll have no problems. As to the soft back window, you'll likely damage it. If nothing else it will be covered in splattered bugs. I would recommend that you take a piece of 1/4" plywood and drill a couple holes in it on each side and zip tie it to the cage over your soft back. It will then take the abuse and you can store it for that continued purpose.
A
AZMountainRider
Thanks
Bill
I have a home made roof, front lexan windshield and the Honda soft plastic rear window. I load it backwards on the trailer and when I put it in the truck bed. I just zip open the plastic rear window and put my windshield down. I have not had any issues and like Bill said, rear tires hit back of bed first instead of bumper or winch.
rocmar
rocmar
4,741
5,776
4 CORNERS
Roll it up...bungee down
no other option...
IMO
Stonewall
Kentucky
Thanks
Bill
I been trailering mine backwards for three deer seasons with a soft back window because I put soft doors on in the late fall and it keeps them from blowing off, but I also bungee them on just in case. there hasn't been any damage to my back window they are tougher than they look.
KYhillbilly
KYhillbilly
553
1,663
Ashland, KY
I bought a Honda towable cover for mine as i destroyed a home made soft rear window and lost a door(bungeed as well) towing backwards. Found the door and now have a Tusk soft rear window. To prevent this i got the trailer able cover.
O
Oregonkirk
14
15
John Day, Oregon
I haul mine loaded in backward. I roll up the back window and no problems so far.
2017 12 26 151856
Reactions: Gassygordo
906UP
906UP
14,399
136,826
da Yoop
I haul mine loaded in backward. I roll up the back window and no problems so far.View attachment 76615
Nice truck! I have the same one, same color in a CrewMax :)
Maybe I'm anal....... I pulled both the windshield & rear window when I towed my Donkey.
115,818
I rolled it up and the windshield down the day I picked it up. I have an 8’ bed tho. Drove it 200 miles no problems but bugs on the window.
BD880077 FC2D 41CB 89DB CCD3640CD897
Reactions: trigger
