Is it struggling to start and then cracking right up on the next try?I need some advice my pioneer 700-2 is struggling to start...!! Thanks
It struggles for bout a minute and then startsIs it struggling to start and then cracking right up on the next try?
Weird. I know mine doesn't start well if I don't turn the key on and let it sit for a couple of seconds. I usually turn the switch and wait for the Honda welcome thing to go off.It struggles for bout a minute and then starts
Yeah it turns over and I recently sunk it but I changed oil three times clean air filter box clean fuel lines clean gas tank just don't knowWeird. I know mine doesn't start well if I don't turn the key on and let it sit for a couple of seconds. I usually turn the switch and wait for the Honda welcome thing to go off.
Is it turning over just not cranking?
As gator said above there has to be water somewhere in it still. I've heard of people having to change the oil several times to get everything out.Welcome Nick.
You sort of left off the "sunk it" detail. Any other things that could be related?
How recent was this? how sunk?? Give as much detail as you can.
When it went under you got every connection wet. A good practice is to disconnect wiring harnesses and add di-electric grease to every imaginable contact.
It was sunk two weeks ago exhaust was full of water gas tank was as well air box full of dried mud oil was milky digital dash went out it starts after about 45 sec- min of turning over and then seems to run fine if you give a little spray of carb cleaner to air box it starts up a lot fasterWelcome Nick.
I put details in thread and photo and once started seems to run fineI'll second what @Gator said we need more details.
Jeez you weren't kidding about being sunk! Did you shut off the motor or did it die on it's own?I put details in thread and photo and once started seems to run fine
Died on its own right away and I did restartedJeez you weren't kidding about being sunk! Did you shut off the motor or did it die on it's own?
Yes I did and I meant to say I didn't restart it until everything was clean but I didn't know gas tank had water thanksBefore you restarted it did you pull the plug and crank it over to get any water out of the cylinder?
Okay thanksOk good. Jeez it could be so many things. I'd first follow @Gator 's advice in post #6. Also might try replacing the spark plug as an easy "who knows it might work" fix. The fuel may still be contaminated too. Try those things first and if you're still having issues it may be time for a compression test.
At least he got a picture though right?WOW! How the heck did you end up in there? That would be a good ROTM entry.
The mud would be my bigger concern. That went all through the engine and you might see it start to smoke soon.
I'm sorry to say that but it is likely.
