P500 HELP. P500 DOWN
ChuckIII
ChuckIII
96
155
Check engine light came on shifter went to ----- just a line. No Speedo at all reads 0 the hole time. Stays in gear till I shut it off then it will shift down then run for 15 sec or so then same problem. It will idle for ever no problem ............
HUCK
HUCK
1,047
2,319
ARIZONA
It is in limp mode . No idea why but that is what happens when the computer senses a harmful problem .
ChuckIII
ChuckIII
96
155
How do I get it out of limp mode?
ChuckIII
ChuckIII
96
155
Did a load test on battery. It goes down to week.....???? Bad battery maybe?
ChuckIII
ChuckIII
96
155
I'm going to take the battery to auto zone in the morning. Have them do a load test also if that's not it I'm stumped .
Reactions: Jshell3
HUCK
HUCK
1,047
2,319
ARIZONA
Careful . I had similar problem on my Honda Rubicon . Auto Zone and O'Rileys both tested it and said it was good . Not believing them , I took it to Polaris dealer , they tested it with the correct equipment and guess what ,? They said it was stone cold junk . Being happy that a battery could cure my sick Rubicon I bought one from them (more expensive than other places) and it was a MIRACLE ! My Rubicon was fixed !
Reactions: Johnsee
ncred02
ncred02
1,030
1,765
Raleigh NC
How long should a battery last in these 500s?
Mines a 2015 and I dont have but 250 miles on it. I do use a battery tender. I connect it every month or two and let it sit a week+ everytime
182,264
A lot depends on how the battery has been treated. Letting a normal battery fall below 50% charge is bad. They charge back up pretty fast but they get hot under a charge, heat is what kills them, warps the plates inside. Deep cycle's have thicker plates and can handle that better, but they usually have low CCA. I run a good tender, that won't overcharge, all through the winter.
Not an expert or anything, just been reading up on it lately. ;)
Deleted member 3748
You have it right. Deep cycle batteries can handle deep discharges and charges (cycles). Standard batteries can handle about one deep discharge. My latest cars draw so much power just sitting there that I get no warning when the battery is about to die. It's just over when I try to start it. It makes me miss the old days when we could go for a month hearing wha, wha, wha, wha, wha, Start!
As I have mentioned before... I play with a solar power panel in the garage. It's a great way to learn a lot about batteries, DC inverters, and electricity as you push your panel and batteries to their very limit. It also gives you a convenient spot to test all of your 12V Pioneer accessories. If you're interested, then I apologize for showing you another hole to throw your money into. :D
74792 606732076013882 826501759 n1
ChuckIII
ChuckIII
96
155
Of course I've done maybe 40 tests on the battery all good. I've checked every wire on this thing and so far far I'm SOL. I'll keep everyone posted when I find it good to the dealer tomorrow
Reactions: Jshell3
Jshell3
Dang.
Please do.
Deleted member 3748
Has anything unusual happened recently? Submerge it? Powerwash? How is the oil level?
Shadesmn
Shadesmn
505
959
Ramsey, MN
View attachment 39039[/QUOTE]
That looks like a fun hobby
