Re: Plow Help - Keeps kicking back!
Is the plow angle adjustable?
Is it leaning like this ==\\ like this ==|| or ==//.
Having it like this ==\\ will cause it to catch more.
Can you adjust the springs?
Tighten them up a bit until you are comfortable with the hit vs kickback.
Are you plowing pavement, cement, or gravel?
Do you have the shoes set correctly for what you are plowing?
Gravel you need them down more then if plowing hard.
