I had my dealer do the first service at 100 miles for 'the record'. So this will be the first one I do.
Is the DCT and engine oil filled from the same filler tube - lower left of air cleaner access? I know there are two drains and the DCT has a separate filter so … what's the scoop? Does the engine oil dipstick measure the DCT oil level too (because it's the same place with two drains)? Answer --> Looks like I'm draining the oil pan and oil tank, so two drain bolts and the DCT and engine share the same oil.
Short version - remove two drain bolts, replace both filters, replace drain bolts, add 6.08 qts, pat myself on the back.
Tips? TIA
Tips? TIA
