I
Took the P500 out for its first "real" ride today. Turned 100 miles so 1st service is due. Anyways after a little ways into the ride I noticed that it was hesitating on up shifts, meaning I would manually up shift while staying on the throttle, and the machine would keep revving for a brief second, but you could tell no power was getting to the ground, and then it would get into gear and there would be a small lurch forward as power got to the ground. In the 40 to 50 miles before today I don't believe it was acting like this, the shifts would be fast and pretty smooth. Also I tried it on automatic mode and it was also hesitating on up shifts. During down shifts there was no hesitation.
Could this be a clutch adjustment issue ? I've watched piston honda's video and could give that a try.
Thanks guys.
Thanks guys.
