High clearence arms front and rear
Tramguage1
Tramguage1
Texan
7,478
30,583
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Let me know what you guys have and why you like or dislike.
20201227 152009
208,726
Those are your stock A Arms, aren't they? We've got Supper ATV A Arms, the gripe about them from me is, you have to unbolt them from the frame to adjust alignment, other than that no issues.
Reactions: Blownzuki
Hometeam
Hometeam
980
4,038
Normal, IL
L and W. I have there front and will be getting the rears soon. J Sport is gtg also!
PaulF
PaulF
1,462
4,814
Front I have L&W. They seem to provide the most additional clearance. I highly recommend them.
Rear I have AMRC. They are GARBAGE, get something else. They provide excellent clearance but they use garbage Heim joints and they hit the exhaust pipe. I had to spend hundreds more on good Heims and modify them to make them work correctly.
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
L&W front and rear here. Absolutely zero complaints from me but I did read about a front arm failure on this forum not long ago. Here, I found the post..
One other thing I like is the lifetime warranty offered.
Here's my L&W front arms, they give great clearance, have stock offset and are not adjustable.
49337399646 724db9cea9 b
Here's my L&W rear radius arms, strong, good clearance and high quality heim joints.
IMG 20201121 134532215 HDR X2
Tramguage1
Tramguage1
Texan
7,478
30,583
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Got a set of upper and lower rears on order from Joe Wooster at Ultra Offroad.
@Lil_Steve
Im very interested in some more pics of the fronts.
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
@Lil_Steve
Just took a few pics in the garage...
This one shows how high up they go for most of the axle length.
IMG 20201229 211216523 X3
IMG 20201229 211305165 X3
Behind the drivers side wheel
IMG 20201229 211413016 X3
Pass side
IMG 20201229 211432529 X3
I tried to get a close up of the welds..
IMG 20201229 212041703 X3
IMG 20201229 212124410 X3
Let me know if you want a pic of a different angle.
@Tramguage1 this is the route I would go if I were you and I couldn’t consider a KRX.
5,425
24,913
