High idle
P
Paul_56
9
Louisiana
I have a 21 honda talon 1000r an it high idles an when i give it thottle it gets higher an the exaust turns red an when i tap the thottle body it comes down some
Reactions: Blownzuki
63,561
Idle is controlled by the IACV. It's located on the throttle body and acts as an auto choak.
Dirty ones will cause high idle. There have also been report of bad ones and wires being broken. The break is not visible.
But with yours being so new... I wouldn't expect to see dirt or broke wires unless you have a good many miles.
lee
lee
Village Idiot
2,335
13,099
Springfield Ohio
You might consider checking the throttle cable.
At "idle" the cable should have some slack at the gas pedal.
The foot pad of the gas pedal should move 1/4 inch before the cable starts to move.
There is an adjustment nut/bolt near the gas pedal end of the cable.
P
Paul_56
9
Louisiana
I dont have any slack in it will that make my exaust turn cherry red with in a few seconds
P
Paul_56
9
Louisiana
Found the problem brought it to the honda shop an was a rock stuck behind a lil piece of plastic by the throttle 5 min fix all good now
P
Paul_56
9
Louisiana
My babby
20210326 161702
P
Paul_56
9
Louisiana
I love it it dont move at all i would recommend doing it thats the best way to do it
P
Paul_56
9
Louisiana
An also i turn my havocs backwards an there a whloe better smoother an more traction
