P1000 High RPM's
oldaker201
oldaker201
31
83
WV
my machine is running around 5k rpm at around 40mph, is that normal? feels like it needs to shift to another high gear
5,433
24,963
Does yours have paddle shifters? My favorite thing about the DCT and 6 speed is being able to 'paddle up' to keep the rpm down when I'm just cruising.
oldaker201
oldaker201
31
83
WV
Seriously though, yes... 5K rpm works out to about 41 mph on these machines. Redline is 8K at 66 mph.
sounds like 5k is normal at that speed then, just sounds like it is wound tight at those RPM lol, im just not used to that yet and im guessing running down the highway at those RPM wont hurt anything
0860silverado
954
1,834
louisiana
Not even close to hurting anything. I run mine at 8K regularly and I have over 15,000 miles with no issues.
Heinecke2
Heinecke2
42
119
Illinois
Add some sort of sound proofing material to the vertical plastic area just forward of the engine. I stuffed some 1/2" neoprene (heavier material would probably be better) in there and while it didn't really quiet the engine noise much it must have absorbed some vibration in that panel.
I did not like going 40+ before adding that material as I "felt" a lot of engine vibration which gave me a nagging desire to upshift.
AFTER adding the neoprene I regularly cruise at 45+mph and no longer have the nagging feeling to shift up.
bumperm
bumperm
1,899
6,778
Gardnerville, NV
Like everyone else has said 5k sounds right. Full confidence the rpms want hurt anything.
Honda is good at making high revving engines. My little yellow Honda has a red line of 9K. It's a 2002 I've had since new, with only 30K miles. So I'm betting they can make an engine that'll turn 5K all day without breaking a sweat!
Think I oughta look at getting a lift kit, maybe portals, as something the size of a walnut would probably get stuck underneath.
S2000
