P500 Holdin' 'er open
F
Flienlow
6
seattle
I run my 520 down a main road often. I flat foot it and run it about 37-39 MPH or at least just under the rev Limiter. Will I throw a rod doing this, or can she take the abuse?
ehart814
ehart814
1,701
3,889
NWPA
Keep the air and the oil clean and it will run wide open for a very, very long time. Mine started consuming a little bit of oil around 3000 miles or so. So I would always check it before longer rides. No big deal.
NTC/TAP Transition Member
11,885
90,617
My one time issue running like that was overheating from a mud clogged radiator on a long ride. Check/clean it periodically for WOT running and should be good. I now keep a water jug and 12v sprayer in the trash can mod under the drivers seat. (thanks @trigger).
