I'll see what I ordered. It was like 15 to 20 bucksIs this the correct harness for a 2020 Pioneer 700 Deluxe I've down a search some sites show that this will work some reviews say it it won't.Want to put some lights on and use a relay and have them thru the switch
Thanks
Power yes. Ground is only when in reverse.So basically looks like plug and play whips for Ignition controlled power?
I tested the connector with key on i only have 1 wire that has power out of the 4. Is there another switch that needs to be on to have the other three powered up?This is what I used, 2018 700-2, plugged into the red capped connector, has 12v at all 4 wires with key on. Much cheaper to buy at the dealer than amazon.
