Honda accessory harness
SD1976
SD1976
23
Can anybody tell me where to plug in the accessory harness plugs into?? I plan on using this to power my winch
That harness is not enough to power the winch. You could use it to provide switched power to the contactor.
Get the $5 Auxillary sub harness 08Z02-HL3-A00 you can use it for switched power.
You will need to wire the winch direct to the battery.
SD1976
SD1976
23
I have the harness wear does it plug in too? There's two female ends !!?
Follow the 12v accessory port wire from under the dash up toward the windshield. You have to unplug and remove a section of it and replace it with the Aux Sub-Harness.
SD1976
SD1976
23
Thanks Ohanacreek!! Found it feel dumb no instructions!!
