P1000 Honda Cabin Comfort Heat Fix
E
Ericthered
Eric The Red
271
522
Sparks, NV
Well, it finally happened. I hit a water puddle in my P1000-3eps and got my ass steamed. First time in one year of ownership. We don't get much moisture here in Nevada. I need to find out what you guys with water do about it. It really burnt my lower back. I was shocked. Please advise on best way to stop this.....
Farmerjohn
Farmerjohn
92
167
Upper Peninsula of Michigan
This happened to my little girl(6). It actually burned her. I layered the firewall type material u can buy on eBay. It helped a little. I then took the rear covers off my P3. This helped a lot!
tincangob
tincangob
200
270
Central Wisconsin
Try installing self stick reflective heat barrier ( firewall automotive rated) 1/4 inch thick on underside of entire seat. Then cover gap between seat frame and rear seat cushion to stop any heat rising up. Have done this to my 2017 P1000-3 and in 104 degree heat in Nevada last weekend my wife didn't complain riding in shorts. That's the real test!
I have a roll of the self stick reflective heat barrier, but have not applied it yet. Doesn't it interfere with maintenance? I am reluctant to cover up access under the seat. Does it come off if you need access?
No wonder Honda has a gas pedal recall - it probably melted. LOL
TripleB
TripleB
20,645
180,466
Caryville, Tennessee
I have a roll of the self stick reflective heat barrier, but have not applied it yet. Doesn't it interfere with maintenance? I am reluctant to cover up access under the seat. Does it come off if you need access?stick it to the bottom of the seat.
Reactions: Redmoon
TripleB
TripleB
20,645
180,466
Stick it to the bottom of the seat.
Redmoon
Redmoon
265
456
Prescott Az.
Ha Ha Ha Good stuff
walexa07
walexa07
396
380
Louisiana
I used exhaust header wrap and I think it works pretty good. Some say it could corrode the exhaust but if it does I’ll just replace them.
Waylan
Reactions: russknight
RB3offroad
RB3offroad
1,722
4,856
Tempe, AZ
We just had the updated heat barrier(comfort kit) but Im thinking of putting the thermos tec on it as well. I was thinking of putting right over the comfort kit. We also added a half windshield and a back window(will a inch on each side not a 100% coverage) which moved the air around. I will let you know what we find out. I just burned my buns a week ago. It was hot and we live in AZ
Redmoon
Redmoon
265
456
Prescott Az.
Wouldn't someone
I purchased
I used Thermo-Tec Thermo Guard under the seat very happy. Placed it right on top of the Honda condom. Just waiting for the Turbo 4000 bilge fan. I think it’s important to move that heat off of the motor.
russknight
russknight
1,910
7,513
Perry Florida
I used this and it works very well.
https://www.walmart.com/ip/Laser-Fi...to-Sun-Visor-for-Heat-Block-UV-Rays/584597509
Heat shield
Reactions: bigr244
russknight
russknight
1,910
7,513
Perry Florida
Did you just lay this under the seat? Did it require trimming?
It required trimming around the seatbelts, the seat latch, and here and there. I folded it so it comes up 8-10 inches behind the seat as well. Not too difficult and it works very well.
Sjc3081
Sjc3081
267
444
Wappinger NY
My previous ride was a CanAm Outlander. The heat from a Pioneer 1000-5 is luke warm at worst compared to my oven thigh roasting Can Am.
Reactions: Urdaddymike
