Honda Fender Clip Remover Tool
66,871
Was talking with another member and they mentioned needing new fender clips because getting them out is a pain and more often then not, it ruins them beyond use.
Vyquju8ySo....
I figured I would share this cheap too I use to easley pull the center head up allowing the body to pull out unharmed.
It's called a "Door Panel Clip Remover Tool" .
It has saved me lots of trouble from having to replacing the clips every time I need to remove one.
You can pick them up online for less the $5.
Amazon.com: Lisle 35260 Plastic Fastener Remover: Automotive
Tool Planet - Door Panel Tool
 571 Tool
Reactions: blkbird305
blkbird305
blkbird305
14
Go smack into a cedar tree... that'll knock em loose.
These panels tools can be had at most auto parts stores for a couple of bucks... in case you dont want to pay shipping.
Reactions: Kingmudd
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
I bet you are right about a cedar tree!:confused:
Reactions: Kingmudd and JACKAL
272,175
I have used a cheap little screwdriver that has an end like a claw hammer. Think it was $2 at Walmart but I didn't have any luck finding a picture of one . It isn't a perfect fit but plucks the cor loose without damaging it.
SuperYeti
SuperYeti
220
375
Vancouver, BC
While installing my gun rack today, i got sick of prying them with a screwdriver, so I took one of my cheapo pry bars, and cut a notch into it and sharpened it to a point to get between the clips and works great!
IMG 20160118 135157 zpssjjcvwrw
IMG 20160118 135201 zpsgwx9ydab
Reactions: Hondasxs and Tflynn
Gator
Gator
The Most Unknown Member
2,488
10,460
Louisiana
Cypress Trees work almost as well as Cedar.
My method is pinch and pull until you've destroyed the dang clip then put a new one in. I think I might try the crowbar do-dad.
Reactions: Tflynn and joeymt33
