Honda OEM Heater
Rayiam
23
North Bay Ontario Canada
Hi
Could someone please give me an accurate or as close as possible, the amount of time it takes a trained Honda Factory Tech to install a Honda OEM accessory interior heater in a 2021 Pioneer 700 2p.
Dockman
Dockman
168
344
My guess is 2 hours
  • Haha
Reactions: Hawk53
Dockman
Dockman
168
344
The inferno I installed in about 3-4 hours tops. That was my first one. Than installed same heater for my buddy and only took me about 2.5 hours. Heater was $400ish
Reactions: ChadD and HBarlow
Rayiam
23
Thank you again. Information much appreciated.
HondaTech
Are you doing the switch panel at the same time?
It is a pain, if you do it the exact way Honda says. But there are shortcuts as far as what plastic needs to come off.
Its like most accessories, you do a couple and they become easier. I'd have to see what flat rate is listed.
Edit: Honda claims 5.5hrs for installation. Bit sometimes we add time because flat rate times may not include all time involved, especially with other accessories needed.
Reactions: ChadD
Rayiam
23
Yes, doing switch panel at the same time as required by Honda. Dealer pretty picky, so I would imagine he is following Honda procedure.
Reactions: ChadD
Rayiam
23
Thank You very much. That is very helpful.
Reactions: ChadD
