P700 Honda pioneer 700 rough running
ckermond
Australia
My bike is running like a dog from idle to mid rev range as if it’s missing every second beat. I’ve checked fuel pump - pressure and volume good, replaced spark plugs - spark appears good, checked fuel injector, cleaned throttle body with throttle body cleaner. Looking for any other suggestions how to fix it.
Mark in Northern Iowa
486
2,162
Floyd County, Iowa
kramnella.wixsite.com
Howdy and welcome from Northern Iowa
Have read about quite a few 700's having your symptoms.
Using the search bar above, 700 rough idle, would show up a few.
This is a good one to read.
Common problems
  • cracked spark plugs
  • plugged air filter
  • blocked muffler
  • seatbelt switch
  • and the bad one, cam lobe wear
Let us know what you find and how you fixed it.
Maybe it can help someone else.
And, post up some pics of your ride.
Everyone likes pics!!!
Mine are in My Introduction below.
Have a good day
Buggyman
Buggyman
44,276
358,441
ne. ohio
welcome from Ohio hope you get it figured out
115,420
Welcome from the States!
what Year and Miles Will help us with this as well.
also post up some pics of the SXS not your bike🚲🤣 when u get a chance . #POIDH
ckermond
Australia
Thankyou. Check muffler, check spark arrester - no carbon. Haven’t found anything yet. Photos attached.
AE709982 AF9C 49B9 94B9 F32754ED3BAD F8938358 BF70 4431 9E5D 361E1CC7185A 7648B62C 19FE 4CA4 B73E 544BE06E44BA 71946E11 55B5 4263 9C86 FB5EEBA4B03A
115,420
Wanted to let everyone know I have fixed my bike. The throttle position censor had stopped working. Replaced the censor and the bike is running well.
You have a Bike also? 🤣
Glad u figured ur issue out
