honda plow/warn
spifyd
spifyd
419
178
newhampshire
much to my surprise the Honda plow will raze so high it will take the grill out. luckily I noticed this be for it happened and have made a pulley system that stops this this from happening. (still a work in progress).the plow will also do this pushing back bank so if you have one or are ordering one be careful.
67,170
Would like to see Pictures of the Honda plow if you get time.
Pushing back bank? Do you meant like when pushing up a bank of snow it will raise up and take the grill out? That would be a issue. Need some type of bump stop.
F
farmer700
80
Yep That Would Defiantly Suck.
* Sorry About The Caps.
fishin2Dmax
fishin2Dmax
186
32
Almost happened to me as well. I would be really curious as to what you did to create a mechanical stop limit? I'm a afraid I'm going to forget one time and take the grill and / or ding up the top of the front bumper. I've found a few things with the Honda / Warn plow set-up that looks as it they rushed it too quickly. The Install of the Mount was one PITA - instructions didn't motioned the need to drill holes. The Warn push tube instructions were even worse. Hopefully, Honda/ Warn will address these issues in the future.
Jerry3
Jerry3
121
Arkville, NY
Would it be possile to put an extention on the cable of the winch, so when its all the way in, it stops, but the plow isn't up too high?
fishin2Dmax
fishin2Dmax
186
32
That's a Great idea! Thanks!
spifyd
spifyd
419
178
newhampshire
it should snow tonight if it does I will take some pics. the arm I made kind of works it still needs more work.
spifyd
spifyd
419
178
newhampshire
That's what I did to stop it from lifting to high but you still have to be careful pushing back banks it can still come up.
On the brighter side it goes high enough to go trail riding. I sent an email to Warn last night to let them know. It will be interesting to see if they reply.
spifyd
spifyd
419
178
newhampshire
Mods to plow.
I made a nut pate to make it easier to remove and install the mount.
I filled I. The ends to stop over lifting. replaced wimpy pivot pins with 1/2 inch pins.made roller doe lift stap
67,170
The yellowish pulley?
Is this what you made to stop it from going too far up?
spifyd
spifyd
419
178
newhampshire
It was but the end up beating up the winch .
Now the frame bracket stops it from going to high . I had to fill in the gap to make that happen. The yellow bully is a ball roller that lets the strap run through so doesn't wear it out I'm using a winch cable from a boat 12 bucks at Walmart steel cable don't last
67,170
Ok.
Ya, I see you added the stops to the plate also. That will help stop it from going up higher then expected.
fishin2Dmax
fishin2Dmax
186
32
spifyd said:
Mods to plow.
Very Nice! I still have one mounting plate nut I couldn't get fully tight due to not being able to get a socket or wrench on it properly (not much clearance or access under the front differential. I shutter at the idea of having to remove this mount - a real PITA. The concept of the nut mounting plate is a great idea!
I'm curious, did you place the plow mounting plate on top of the front underbelly skid plate or underneath it?
spifyd
spifyd
419
178
newhampshire
the front bumper plate is between the frame and the plow frame. nut plate sits on top off frame lip even while the plow frame is off. no top wrench. o and buy the way I though the alen head bolts in the trash. we all know those would not come out 3 years from now.
I am hopping I can leave. it on all year it will make a good bash plate.
Becht313
Becht313
35
75
New Hampshire
Just took the plow (from spifyd) out on the 17 700-4 deluxe. Man... I'm glad I know this guy! He worked all of the bugs out of that plow setup. Beast. Pretty sure I just kicked winters ass...
Reactions: allgm1 and joeymt33
