Electrical capacity copied from an answer to someone's question. They guy already had aftermarket lighting and wanted more (I don't have that thread so no context).
PaulF on Talon lighting -
Second, that is almost 400 watts just in lights (if they are all on at the same time) and probably a little more due to voltage drop in the wiring. The charging system is pretty big on the Talon (700 watts at 5000 RPM) but the running engine probably takes up around 250 watts. With all the lights on, you are pushing the charging system almost to its max. 13 on the aux battery is almost net charging (12.7 is fully charged for a lead acid battery) so it is barely keeping up at that point. Any more accessories may put you in a discharge state.
