Looking at spare options. Is Honda's bolt pattern unique or are there any other OEM that use the same? Pretty sure Polaris' are different.
I think can ams are 1mm off as well..4/137Looking at spare options. Is Honda's bolt pattern unique or are there any other OEM that use the same? Pretty sure Polaris' are different.
The Pioneer 1000 bolt pattern is 4x136mm, some Kawasaki and Cam Am are 4x137mm. There is enough play in the lug holes to allow either to work in most cases.Sorry - not sure what 1 MM off means?
The Pioneer 1000 bolt pattern is 4x136mm, some Kawasaki and Cam Am are 4x137mm. The is enough play in the lug holes to allow either to work in most cases.
I have ITP SS212 with 4/137 pattern, they work fine 800+ miles no problems. My opinion is Honda wants you to buy Honda wheels.The Pioneer 1000 bolt pattern is 4x136mm, some Kawasaki and Cam Am are 4x137mm. The is enough play in the lug holes to allow either to work in most cases.
Them wheels call for flat faced lug nuts all I can find is 12mm 1and 1/2 beveled need help would like to install ss212 also thanks RickI have ITP SS212 with 4/137 pattern, they work fine 800+ miles no problems. My opinion is Honda wants you to buy Honda wheels.
I got my wheels and tires from sxs stuff. I have ss212's, they supplied the nuts. They may be able to help you.Them wheels call for flat faced lug nuts all I can find is 12mm 1and 1/2 beveled need help would like to install ss212 also thanks Rick
