P1000 Honda wheel bolt pattern match other OEMs?
txsurfer
txsurfer
496
990
Santa Fe , TX
Looking at spare options. Is Honda's bolt pattern unique or are there any other OEM that use the same? Pretty sure Polaris' are different.
CPope
CPope
352
1,151
Pulaski TN
Kawasaki teryx is only 1mm off, the wheels will fit with no problems.
Reactions: swsebek
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,569
Greenville, Mo
I think can ams are 1mm off as well..4/137
Reactions: swsebek
BAMASXSRIDER
36
64
ALABAMA
Sorry - not sure what 1 MM off means?
The Pioneer 1000 bolt pattern is 4x136mm, some Kawasaki and Cam Am are 4x137mm. There is enough play in the lug holes to allow either to work in most cases.
4/136 for 1000
4/110 for 500 & 700
I don’t remember thread/pitch off hand for each but both are non typical.
4/137 wheels will work, I think someone at Honda didn’t zero their caliper.
Reactions: Bad_bowtie and lee
txsurfer
txsurfer
496
990
Santa Fe , TX
The Pioneer 1000 bolt pattern is 4x136mm, some Kawasaki and Cam Am are 4x137mm. The is enough play in the lug holes to allow either to work in most cases.
That's what I thought but wanted to make sure. I see some take-offs from other makes on CL from time to time.
BTW - what offset would be needed to run a single spare on all 4 corners?
Reactions: Hondahauler
txsurfer
txsurfer
496
990
Santa Fe , TX
well it appears that most people must be running 4/137's because not many people offer 4/136 14's.
Someguy
181
179
Krakow Wi.
I have ITP SS212 with 4/137 pattern, they work fine 800+ miles no problems. My opinion is Honda wants you to buy Honda wheels.
Reactions: swsebek
nglauer
nglauer
45
20
My buddy had Yamaha viking wheels on his 700. I believe they bolted on without any mods. I can't speak from experience though, as I haven't bought a pioneer yet. Still waiting to pull the trigger on a 1000-5 or something else...
K
Karmen
0
Arpin wi
Them wheels call for flat faced lug nuts all I can find is 12mm 1and 1/2 beveled need help would like to install ss212 also thanks Rick
Someguy
181
179
Krakow Wi.
I got my wheels and tires from sxs stuff. I have ss212's, they supplied the nuts. They may be able to help you.
ofrcboy
ofrcboy
501
572
Oregon
Fuel wheels sells correct wheels 4/136
