Talon Hood pops up while driving
bigblueaz
bigblueaz
67
Arizona
So while on my last break in run I sped it up a bit.
While going around 40mph on a slightly bumpy road the front of the hood popped up out of those rubber grommets twice. The hood wouldn’t come off cuz the latches hold it. But i had to stop and push it back down. Annoying and certainly an flaw
Anyone else have this issue?
Ideas?
Talonpalooza
Talonpalooza
122
237
I would guess you didn't have the two tabs on very front inserted into the hood on front. If you have it installed in those front two tabs (if they are not broke) and the two release knobs locked down, it is not popping up. Also, check that your rubber grommets in the 4 push pin areas for hood are not deformed or missing.
bigblueaz
bigblueaz
67
Arizona
Thanks Talonpalooza...
The first time it did it the wind got under it and rear popped out too. I pushed them all down and could feel them set into the rubber grommets. They really only have an in or out position. The 2nd time just the front came out, but I stopped fast because i knew the rear would pop out. I pushed them in again. The rest of the ride was slower. I’ll inspect it. I can see maybe the first time if it loosened while we were on our long slow ride or one of my friends checking it out didn’t seat it all the way. But not the second time. It pushed them in all the way.
Very doubtful all grommets would be deformed
Hopefully i see something it there that somehow stopped them from seating all the way. Cant imagine what
Maybe someone else will experience this so im not the only one. Or Im just special :)
66,869
Your not latching the front tabs. Take a look at it and you will see them. They slide from the front back and hook the front down. Once you do this there is no way the front can popup without pulling out of the push tabs first.
That should fix your issue if there not broke already.
66,869
Under the hood here.
Its like a J hook. You must hook them before pushing down the push tabs. Da39a89cc53c9cc7727b75fb942bb3d0
wrighteous
wrighteous
108
501
better make sure its on those front tabs mine blew off over the fence 20 ft in neighbors field at 50 mph
wasnt my fault tho i wasnt the one messing with the hood!
bigblueaz
bigblueaz
67
Arizona
Thank Hondasxs, that was it. I feel dumb, glad to hear someone else has done this. I even rotated the rubber grommets since they are oblong to the "tighter" direction but the hood still felt loose. Like wrighteous said tho, not my fault, I did not open the hood, it was some folks at camp checking it out...BUT I did not catch it nor did I know.
So is there a DUMBA$$ of the month thread? I get this month :)
Haha
mikeherber
20
Minnesota
my hood flys completly of at higher speeds no matter how I turn the grommets flew off all three times out now with 33 miles on it
66,869
Make sure you are hooking the front hooks. If you do this it will not come off.
Welcome to the club BTW.
I know you're going to go look at it. can you snap a picture for this post.
Flip the hood over and look at the front underside, There are 2 hooks that must latch.
Talonpalooza
Talonpalooza
122
237
If hood is properly installed it will NOT fly off. If two front hooks properly seated, 4 grommet tabs connected and the latches locked down correctly, the roof is NOT flying off. I have 400 miles on my machine with 70+mph and rough terrain and never had an issue...However, if one is not cognoscente of making sure all points are connected it will fly off. If you read above, another poster found out the same way.
Someguy
181
179
Krakow Wi.
Your not special. HaHa I bought a talon x yesterday. Took it out today. Had the same problem. My buddy saw the two tabs. Problem solved. I had a pioneer 1000 EPS 3p. Traded it on the Talon. Absolutely love the Talon, much better trail machine than the Pioneer.
