P700 How many run Same size tires on all 4 corners
A
av8or
IMG 2649
IMG 2648
Since I came and asked and got some tips from you all. Here's a couple pics so you can see the results. ITP SS212 wheels 12x7, 5+2. With Tusk Teerabites 27x9x12 all the way around. I think this setup will work well for my application. IMG 2647 IMG 2650
xltman
xltman
188
369
US
Looks good. That was a tire I was looking into next time. Let us know how they hold up.
swsebek
swsebek
2,854
5,828
pa
Glad to see you got it figured out.Those tires should wear well
Reactions: Deluxe700
Brianr117
10
Wyoming
Well I think I've decided. Going new ITP SS212 wheels and 27x9x12 all the way around. I want to be able to clear my garage door without any problems and I use a plow in the winter and don't want issues with rubbing. I think ill go with Tusk Terrabites.
Are those going on the stock wheels
are these going on stock wheels?
Deluxe700
Deluxe700
856
1,101
Central Arkansas
That makes sense @JTW .... I didn't think about that..
I’ve got 28x10x14 on stock deluxe wheels so that’s 1/2” on each side with less flex in the sidewall vs a 12”... and I’m considering adding some spacers. @Plumber32 has some stock 12’s but I didn’t remember if he added spacers
Deluxe700
Deluxe700
856
1,101
Central Arkansas
Some folks had told me to stick with the 12" stock deluxe wheels so you have more sidewall for a "squishy" softer ride...and some folks say go up to 14" for the good looks and for better handling...but in either case the spacers sound like a good idea for stability..
Yup.. opinions are like assholes around here. And we’re all assholes!
But to me the side wall height is less important than the width in this case.
66,162
No spacers but 5+2 wheels
Reactions: Deluxe700 and JTW
66,162
28s and 12" ride great. Big difference than 28s and 14s
Reactions: JTW
JimmyA
JimmyA
1,644
5,503
Northeast texas
Today, I had a delivery from Rocky Mountain ATV" Tusk Terrabite" 27/9/12! Discount Tire & Wheel mounted them to the stock deluxe wheels looks great! I am planning a ride next week to ride BMRV.com and a June ride in Colorado backroads. I think they are going to serve the purpose!
Reactions: joeymt33 and JTW
Budman
Budman
118
322
Maple Ridge
Stock rim size is 12x6 up front, how wide can I go? can you run 27/10/12s all around?
P
PolkaJoe
90
103
NEPA
Thinking of adding a spare on board. Would a stock front rim work temporarily on the rear to get home?
Budman
Budman
118
322
Maple Ridge
K input needed, blew my sidewalk out on the stock 700 tire, was thrashing pretty bad and will do more of, even though these are new I'm just going to say F IT and get all 4 new tires
Enough babble
Question: I know your shouldn't go more then 9 wide upfront without lift and offset blah blah
So should I go with 27/9/12 all around or 27/11/12 all around and do it right and make them fit.
Anyone rock 9 wide all round?PIZZACUTTERS!
