P1000 I like the best deals:High lifter control arm deal!
Robobrainiac
Robobrainiac
2,550
8,957
As the title describes I like deals, coupons, promos, whatever you call it to get good prices. I just wanted to pass this along in case anyone else is looking for a neat deal. This is the high lifter arched control arm for the rear of the pioneer 1000. I was able to get it thru an offer of 175 including shipping. I think the high lifter website sells them for 270. It shipped today after a couple days of waiting and it's marked for delivery on Monday the 28th.
ToddACimer
ToddACimer
Pioneer 1005-2
3,669
15,484
Oshkosh, Wi
I have highlifter arms and they work well. Im tempted to upgrade to SuperATV and add a bit of wheelbase though
208,725
I would look for some that are adjustable without talking them lose from the frame mounts?
Reactions: Isaiah
Robobrainiac
Robobrainiac
2,550
8,957
I really contemplated the offset rear arms. I am for sure getting offset front arms. My goal is only 30" tires so I decided offset for the rear was unneeded cv shaft stress. So I got the arched high lifter arms.
Reactions: Isaiah
ToddACimer
ToddACimer
Pioneer 1005-2
3,669
15,484
Oshkosh, Wi
I don't have any plans to adjust them more than once and I really don't like Heims on a-arms, especially some of the cheap garbage ones you see on side by sides. Just personal preference
Robobrainiac
Robobrainiac
2,550
8,957
I updated the title so it was a little more easy to see what the thread is about.
Reactions: CID and Isaiah
Robobrainiac
Robobrainiac
2,550
8,957
I should have mine in the mail on Monday. I will put some pictures on here of them.
Gabbas
Gabbas
280
701
Humboldt, Iowa
Do you not need to replace the upper control arms when adding these?
Sent from my Pixel 4 using Tapatalk
Reactions: Isaiah
Robobrainiac
Robobrainiac
2,550
8,957
Correct. These are only arched for the rear so it replaces the lower control arm for clearance.
Reactions: Isaiah
Robobrainiac
Robobrainiac
2,550
8,957
Give lift? Or add wheelbase for bigger tires?
They do not add any lift and they do not add any wheel base. They arch to give you more ground clearance. Here is the manufacturer website link to give you some more information.
Reactions: Isaiah and Gabbas
Robobrainiac
Robobrainiac
2,550
8,957
I updated the title to now include front and rear control arms. I used a 15% off coupon code to high lifter's website. You text OUTLAW to 37931 and they send you a coupon code. The front control arms with ball joints pre installed are currently not in stock but it let me backorder them using my code. I did get the rear in the mail from ebay today. I haven't opened the box yet.
Robobrainiac
Robobrainiac
2,550
8,957
Here is a picture of it
IMG 20200929 063336 01
Reactions: Isaiah
TI722
TI722
111
650
IL
  2. Other Brand
Thanks! Just placed my order for both. The coupon code they sent me was RKLE15 not sure if that will work for anyone else but you can try and it will save you the trouble of signing up then requesting out of their emails/text.
Reactions: Robobrainiac
Robobrainiac
Robobrainiac
2,550
8,957
I just checked my text and it was the same code for me too.
Reactions: TI722
Robobrainiac
Robobrainiac
2,550
8,957
I opened the box to my rear control arms this morning. The box as you see it is how it arrived with an address label on it. I opened it up and everything looks great. Everything was well packed. It looks like I got all the bolts, instructions, and some stickers. My only complaint is the right side control arm where the grease fittings go there are burrs from where the holes were drilled. The threads look good. The left side was fine. I will clean it up a little. Most likely it will come off with a rag I bet. I will have that posted in the last photo.
IMG 20200930 063246 IMG 20200930 063511 IMG 20200930 063649 IMG 20200930 063844 IMG 20200930 063847 IMG 20200930 063935
TI722
TI722
111
650
IL
  2. Other Brand
Nice. We have a trip planned to Tackett and RRB coming up Oct 21-25. Really hoping to get fronts in time for that but I never asked when they thought they'd be done. May have to make a phone call today. I remember seeing somewhere that guys were welding an extra brace somewhere on the front frame where they bolt on. Need to find that thread so I can do that at the same time.
Reactions: Haldog77 and Isaiah
TI722
TI722
111
650
IL
  2. Other Brand
got a hold of Highlifter yesterday afternoon. said fronts should be done and ready to ship the middle of next week. hope they're right, I really want to get these on for Tackett.
Sloverado
Nebraska
So can you for sure clear 30” tires without rubbing when running front offset highlifter arms?
Reactions: Isaiah
Gabbas
Gabbas
280
701
Humboldt, Iowa
From what I've seen yes with front forward a arms you should be able to clear 30s no problem
Reactions: Isaiah
