![Mkmcdnl](/data/avatars/m/27/27718.jpg?1607385380)
Mkmcdnl
Hi to all and happy holidays
So start to finish, 3 hour install time. The only issue I had was th the cab heater vents the hole must be exactly
2-1/2. Inches. You Can actually force the vent through the hole even when exact. I didn't have the exact hole saw. Would recommend having that. Actually no wiring involved. You unplug the accessory socket and they have the exact plug ends to go to the heater. The air vent hose was recommended to be connected with zip ties. As all 4 connect to the heater from the bottom. I installed 2 self tapping screws to each connection. FYI.. The inferno box flaps are an exact fit to cover the radiator. Am going hunting tomorrow. I will update about how it Works.
