It shut down on me!?
pete_plp
pete_plp
USA
  1. Talon X4 LV
Hello everyone,
I’m a relatively new Honda talon user, having driven less than 400 miles on a 2021 1000x-4 fox Live.
I experienced a very puzzling behavior of my machine, and I was wondering if anyone experienced something similar before or would know a possible cause:
While riding with some friends over the weekend, we ended up taking a trail with a very steep hill - hard to say the steepness degree but was prob close to be worth a black diamond. The 3x 2 seaters machines in front of me really struggled with traction, up to a point I was wondering if it was a good thing to engage with a 4 seaters. Regardless, I went up on 4wd, low gear and in the steepest part my right front wheel started losing traction, and then the weirdness thing happened; I pressed the gas, even more, to get over it and the machine just shut down on me!? I immediately shut the key off, restarted, reengaged 4wd, low gear and HSA… but it happened again right after losing traction and then again… a 3rd time. At that point it was getting dangerous to go back given that I was losing power steering control when it was shutting down, so I got my passengers out, and we tried to go back just a little bit enough but to get more traction (as it was too dangerous to reverse all the way back down)
One rider then suggested that I try 4wd, Low but in Manual mode instead of automatic, which did the trick and got me up with way less struggles.
During the day, I then tried more reasonable hills, and it worked like a charm in manual mode. I was also able to keep it at higher rpm giving me the wheel power without issue
So we came up with the theory that the automatic mode was probably trying to shift gear at some point and was struggling to do so…but why the shutdowns on steep hill!?
Thank you in advance for any inputs
Sheetmetalfab
Sheetmetalfab
2,172
13,598
Alaska
Hello everyone,
Sounds like a live valve specific, front wheel speed sensor issue…………
I’ve never experienced it in my non live X4.
I wonder if you have a bad ground, or bad connection that fails when there is wheel-hop? (Vibration)
Unless you were low on fuel?
Doesn’t seem probable though.
906UP
906UP
14,270
135,340
da Yoop
You've already figured out the issue. When in auto the ecm will shift at a given rpm relative to throttle input, etc. I've run into similar situations in mud but never had it shut down completely, usually it will bog and I was able to catch it before it stalled. As a rule if I'm in low range I'm also in manual.
pete_plp
pete_plp
USA
  1. Talon X4 LV
Ouf! I would prefer this explanation. 😰 sheetmetalfab scared me for a bit.. I relocated my gauge cluster and swapped the live valve module… but no issue so far
thank you all for your inputs
3E554356 DE76 477A 960C 3C4CAC84D023
Hilgart2017
Hilgart2017
16
25
Texas
Hello everyone,
I’ve had that problem before on my 19 talon tried to go up a steep muddy hill in 4-hi in automatic and it died on me. Swapped over to low gear and it was good. Although mine bogged down because of the mud which is the main reason it died on me, but I’d assume the steepness of the hill put too much of a load for the gear it was in in auto which caused it to die out. And since u swapped to manual u were able to keep it in a lower gear which gave the extra torque to get u through it. Generally low gear manual is the way to go in these machines ,at least from my experience, when dealing with steep hills. Hope this helped
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
I got myself into a little trouble one time in my Talon and I believe the steep angle I was momentarily stuck in caused a low oil pressure situation and the Talon shut off. I restarted it and it shut off again. I honestly don't remember if the oil light came on or not but I was able to winch myself out of the situation and once I was on more level ground she started right up without any more issues.
