Multi ITP Blackwater EVOs new sizes
39,079
I was just checking out the two new sizes. I find it interesting that the 32" Evo is only 3 lbs heavier vs the 30". Also, how can the Mayhems be 54lbs in 32"? I know there's a 1" difference in tire size but that's crazy.
F0d96f7f584745eaf8e5ce7390665a9c
D544757d1861e3a1831762c47e1f88a1
Reactions: 500
39,079
I may need to buy one and see if it's a true 30" tire. If so, that would be great. At 36lbs, that's not bad.
Reactions: 500
39,079
not true to size.
I know from experience. I've had multiple sets. I hope I can get these and they will be 30". If they are any higher, I won't like them.
My 30" EVOs were 28" tall. This pic shows 30" EVOs next to 30" roctanes.
74d628b69cf4f2b50636beef39716f8c
I contacted ITP and they told me they are true 30" at 32psi!!! That's crazy as I usually run 8-10 psi.
Reactions: 500
39,079
32 psi in a utv tire that sounds crazy
That was very disappointing to hear them say.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
32psi? Jeez what do they do, seat the bead then measure them? Can't imagine running that kind of pressure.
Reactions: joeymt33
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
I think I'll just get 28" next set. No sense in paying more for something that isn't there. Like 2" lol.
Reactions: Tflynn and joeymt33
BigCypress73
BigCypress73
23
35
florida
Im thinking about getting the 32" BW if they run close to 30", but Im not sure what effect the 15" wheels and 30" tires will have on clutch. Im not worried about clearance. Is this to big??
Sjc3081
Sjc3081
263
442
Wappinger NY
A true 28” tire mounted front on stock wheels or 5+2 wheels are the max height you can clear without rub, full lock in reverse.
William
William
1,442
2,887
Flowood MS
So what does a 28” evo measure to at 10 psi?
56,721
That's floor to top of tire with full weight of bike on it
56,721
I bet they are true 28 then... with no weight that is... Thanks.
Yep, I think they measured 28.5 at 32 psi. I left them like that over night then brought them back down to 10. They were right at 28 but lost another 1/2" once they settled.
