Just Noise
roughrd00
30
51
az
It seems that many riders think that the noise from the P1000-5 is OK. I have a 2018 PK5 and it was not as loud as it is now after the dealer
changed oil and had two recalls taken care of. Yes I have a roof and windshield but the gear noise and the shifting seems a little excessive.
I have owned Honda TRX 420's previously and the noise was never a problem.
Has anyone tried to deaden the noise under the front seat and even the rear bed. Not sure if this is done that it might affect the heat dissipation of the engine.
Just not a pleasant experience when riding with others as it is hard to carry on a conversation. Would appreciate any comments.
Reactions: ChadD and JenElio
roughrd00
30
51
az
You say the dealer changed your oil?
Have you checked the level since?
How about the sub-trans oil?
I'l check the sub trans oil under the seat. Many reports of dealers draining the wrong plug.
Thanks...I am never satisfied with any oil changes on most of my vehicles....You are correct and I will check this. Did not see any leaks but that could mean NO oil too.???
5,425
24,913
I've ridden in 3 Talons and a Rzr of some sort, all 4 were mechanically noisy to the point of possible long term hearing loss. I always wore foam earplugs on the bikes and will continue that in the SxS. I think they're easy enough to talk over and not willing to damage my hearing any further - hearing loss is permanent and progressive. Since hearing damage isn't particularly painful, we tend to ignore it until it's too late.
208,726
Tell me about it, I wear hearing aids now! I decent pair start at $ 3,000.00
  • Wow
Reactions: CID
208,726
I just got a quote for my sons aids... $ 8,200.00. Choke spit cough aack!!!
Yep and figure replacing them every five years. Take care of your hearing.
Reactions: TripleB
5,425
24,913
What Smitty said, take care of your hearing gentlemen, there aren't any do-overs.
I have these scattered around the shop, easy on, easy off and hang around my neck comfortably. Angle grinders, air tools, the radial arm saw and my drill press are painfully loud.
1614047486023
Youngone
Youngone
16
60
Manitoba
Did you ever deaden the noise level down to bearable
roughrd00
30
51
az
Yep.... all the oil was good and the last ride seemed a little more quiet but maybe I just have lost some hearing in one or both ears LOL. The temp was good even after I put the storage box on the front so for right now will leave it there as it worked out well...Thanks for the good suggestions.
xltman
xltman
188
369
US
I have a 700-4 and had a lot of the same issues. The best noise and heat upgrade that I did was to wrap the exhaust. Cut the noise at least in half and the heat. Cost me $30 and two cans of beer.
Sent from my SM-G973U using Tapatalk
PJon
PJon
792
3,214
Arizona
I also have a 2018 P1k5, but I wear a headset for my communications radio and that keeps things nice and quiet.
115,700
Or just buy a jeep🤷‍♂️
