Kemi Moto LED Headlamps
shadybrady
shadybrady
14
58
Middle Tennessee
  1. 1000 6 Crew
Anyone have experience or suggestions on wiring the LED-Turn Signal Lamp. The brown wire is obviosuly the turn signal wire but I tried everything to wire it to the Kemi Moto Street Legal Kit existing lights and will not work. There is power to the lamp and I can put 12v on the brown wire and it illuminates. The instructions are garbage and I have reached out to support which has been non existent. Do I need to add a relay or something? I read somewhere that the street legal kit has alternating power ground to the lights so I would not be able to tap into that existing source. Any help or comments are welcomed.
Thanks!
KEMI Moto LED Headlight with Turn Signal for Pioneer 1000 700/ Talon 1000​
SKU: B0801-05306-CL-KM
KEMIMOTO LINK
115,929
Never knew there was such a kit?
Looks cool. If its anything like the other aftermarket China LEDs and Kemi Moto is no different in that reguard, the wiring is always a Fuc show to figure out, backwards and the distructions are not right. Id call there customer service and see what they say.
Hope they can help get u going.
67,906
Got to be something easy your overlooking.
Positive to the brown should be all you need.
Need to verify the singal kit is switching the positive line and not the ground line.
If it is the ground. Then you may need a relay..... That will double complicate things for sure.
Reactions: Remington
906UP
906UP
14,849
141,109
da Yoop
I believe @JACKAL has a set of these. Maybe not Kemimoto brand but I'd be they're all made in the same factory regardless of the name.
