P1000 KFI plow adjustment
K
Kelldog
55
120
New to plowing snow and new to using the KFI plow. Should the plow shoes be contacting the ground flat when the blade is resting on the ground? the top of my plow is too far forward for this to happen which means the front of the shoes dig into the ground with the rear of the shoes well off the ground. this is telling me the blade is also out of adjustment contacting the ground meaning its angled to dig into the ground too much. So bottom line i have to offset this by raising the plow higher to keep from digging into the gravel. I need at least 6 inches of snow to look like i am doing anything. the only adjustment i see is the spring tension which is for sensitivity when hitting something. currently i dont use the shoes because i have to run the plow so high but just using the shoes as a means to explain my problem
Reactions: Buggyman
john790
357
1,093
Clinton ohio 44216
Your attack angle is off.Look where the plow rests with sprinds on and see if you can adjust that.So the plow rests father back at the top of the plow.
5,406
24,778
Pics of the plow angle and the installed mounting hardware would help and ever body loves pitchers. 😍
Jerryg
Jerryg
12,035
95,516
NEPA
Yes, you have to move the allen head stop bolts to a different position. I had to do the same.
K
Kelldog
55
120
Mine has a block that the plow rest on. I have the blocks adjusted to lean the plow back as far as it will go. Not eonugh.
Reactions: Buggyman
Jerryg
Jerryg
12,035
95,516
NEPA
Pics please
Reactions: CID
Buggyman
Buggyman
44,123
357,412
ne. ohio
Reactions: Kelldog and CID
Buggyman
Buggyman
44,123
357,412
ne. ohio
Zoom in on the far-right picture and look at the Allen bolt location and the angle of the shoes in relation to the floor. remove the Allen bolts and tilt your blade back to a more vertical position that should solve your problem. unfortunately the other poster this was sent to never responded as to whether it helped him or not.
K
Kelldog
55
120
Dang that doesnt look anything like mine. I bought mine used. Now i am wondering if its a KFI to begin with. I need to look online to verify what i got
anyone have a picture of the attack angle adjusted for gravel uneven surface? Pic of it on flat concrete for illustration
Reactions: Buggyman
Buggyman
Buggyman
44,123
357,412
ne. ohio
Post up some pics one of these guys will know who makes it.
Reactions: CID
K
Kelldog
55
120
Dang i have the denali pro. geez. Attack angle pic would help me out regardless. Gravel uneven surface.
Reactions: Buggyman
Buggyman
Buggyman
44,123
357,412
ne. ohio
Screenshot 20230223 0814162
Reactions: toddvdh and Jerryg
Buggyman
Buggyman
44,123
357,412
ne. ohio
Do you have anything that raised the sxs (lift/ larger tires). Pictures of the where the blade is mounted to the push tube would be a big help. POIDH. ( pics or it didn't happen) as stated earlier we like pics. :)
Reactions: CID and Jerryg
K
Kelldog
55
120
No all stock. This is the 72 inch model so it weighs down the front end a little making it worst
Reactions: Buggyman
Mark in Northern Iowa
486
2,162
Floyd County, Iowa
kramnella.wixsite.com
uhm.....................................
4 people trying to help you.
3 of them asking for pics to help.
No pics from you, but then you ask for pics??????
I only have gravel and grass.
Drop the blade, some where that it looks level.
Adjust the feet so the blade is at least an inch off the ground.
Do NOT plow the first snow.
Drive over it to get a froze pack.
edit to add
And Always push back as far as you can.
Once it freezes, yo will not be able to move the pile.
Have a good day
StewB
StewB
720
3,340
What Mark said if you're plowing a gravel driveway. ☝️ ☝️ ☝️
The stop-block allen bolts are under the springs on both sides of my 72" KFI.
They're right above the main mounting bolts.
1677191198761
Reactions: Buggyman
Buggyman
Buggyman
44,123
357,412
ne. ohio
He said he has a Denali which is supposedly a diff. set up but no pictures to help. 🤷‍♂️
Reactions: CID
toddvdh
toddvdh
1,103
7,286
Green Bay, WI
Yup. A couple pictures of your plow and a bunch of could tell you what to adjust.
attack angle is a tough one. I saw the chart up above, but it depends on the type of snow also.
