Leaving Talon key on to listen to stereo
K
KenThompson
281
624
Mulino
Since the Talon doesn’t have an “acc” on the key switch, can I leave the key on without the engine running to listen to the stereo?
Reactions: Isaiah
1Ktrailrider
1Ktrailrider
183
282
Pennsylvania
I'm under the impression that the hour meter will still count when it's in the ON position. I haven't tested it for a while but on my pioneer 1k I'm almost positive that it turns the hour meter with the key on and the engine off.
21,759
93,329
@KenThompson Using the key will also run up the hour meter.
Reactions: TripleB
K
KenThompson
281
624
Mulino
Ok, thanks. Just another switch!
NTC/TAP Transition Member
11,882
90,571
Some what related. Is there any damage to ECM, etc with the key on for a radio, for periods less than a concern for killing the battery? (P500). I am not concerned about an hour meter running up.
Reactions: Isaiah
5,756
26,436
Because I know I'll eventually (and probably repeatedly :oops: ) leave the key on and hearing that the hour meter will probably run during those times, I added a separate hour meter that wraps around the plug wire. It'll be interesting to see how far apart they'll get over time. fwiw: a regular motorcycle hour meter's lead is 'just' long enough, barely, for dash mounting.
I 8zVFtNN XL
I KmgWFHZ XL
A simple bracket and double stick foam tape -
I SmZtDmG M
Reactions: Isaiah
1Ktrailrider
1Ktrailrider
183
282
Pennsylvania
Isaiah. I'm just curious why you wouldn't just swap your accessories off your ACC line? Your entire maintenance schedule and resale is dependent on the "actual" hour meter. Just wondering..
Reactions: CID and ohanacreek
That’s right, we just change the oil when we get damn good and ready. 🤣🤣🤣
I know how many miles is on my machine but couldn’t tell you what the hours are....
Reactions: 70Bones and trigger
1Ktrailrider
1Ktrailrider
183
282
Pennsylvania
I differ from that opinion. Hours are alot more important then miles. Especially if you drive slow and hard or if you have excessive idle time (like me). Also why the maintenance reminder is on hours AND miles.
I think it was repartee....👍
68,377
Well... I disagree haha...
Hours are subject to false increases. Miles are not.
This would make a good poll. I'll build on and post link.
Reactions: CID and trigger
11,882
90,571
If hours don’t factor in RPMs, its all a swag concerning engine wear. Glad a Honda engine is tough enough to handle any fudge factor. LOL
Reactions: Montecresto
1Ktrailrider
1Ktrailrider
183
282
Pennsylvania
The only reason for false increase would be leaving the key on. if I changed my oil on miles I would be well, over the recommended service. I have 908hrs and 7000.
5,756
26,436
I've always wanted an hour meter, it's simply another data point, most useful for engine hours. Honda's choice to have it run whenever the key is on makes absolutely no mechanical sense to me, it invalidates the data. :oops:
I always wondered about that myself...🤔
Reactions: CID
