Light Bar Mounting Location (& Justification)?
USMCsilver
USMCsilver
109
147
US
Roof?
Hood
Bumper?
I am kinda thinking to stay away from roof because I'm worried about it getting beat up by overhead obstructions.
I'm hesitating a hood mount, because I'm concerned about glare coming off the hood and distracting from overall light throw.
The bumper seems like the smartest decision. It'll be low so it won't give much of a halo affect when any dust is kicked up. There'll be no glare off the hood. Zero field of view obstruction for small passengers.
Any advice/input on any of this?
Reactions: RobSparre and sharp
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Roof?
Hood
Bumper?
The hood is the best because the roof and bumper has the biggest chance for damage. If I would put the light bar on the roof it would not fit in my garage. If I would put the light bar on the bumper in tall weeds and deep water the light bar would not help very much.
Reactions: GPR1500SC
208,726
Out of the 3, put it on the bumper, not sticking out but flush, you will be fine.
Use a 1000 Watt head lamp, it will light up your would, but your back will hurt from the battery weight.
Reactions: sharp
Roof?
Hood
Bumper?
0048ecbf9a2c257d4d779aeb3954fb41
30220676a0c7ebf1646c177722e688f5
Pushed trees and brush down , no damage. Roof adds weight up high. I know it's only 10-15 lbs but it starts to add up.
My 700 was a bloated fat cow, top heavy like Dolly P
0c2b826683eb7405b52e3c6be5146f9c
Moved everything lower on 1000
E
elkguide
3,377
7,964
Vermont
SWEET looks.
Reactions: ohanacreek
208,726
Lower/lighter, is where I'm headed
Roof?
Hood
Bumper?
Sounds like you already have it figured out where you want it. I have mine on the bumper but sitting back a few inches to protect it. So far I have not damaged and I am by no means easy on it.
E8d1e0dcfb349e5ee0341f3d3cf1918c
" jak9922" lmfao grilling hotdogs on a stick over an open popo hahahahaha
USMCsilver
USMCsilver
109
147
US
That's nice!
Got a link, by chance?
I was thinking about a straight 20" or 24", but I really like how clean that looks.
Sent via TapaTalk on S7 Edge.
That's a 42 inch curved, it matches the curve of the stock bumper pretty good.
Here's a link, start reading on post 129. If you don't find exactly what you're looking for, let me know.
P1000m5 - Traveller II
Reactions: sharp
USMCsilver
USMCsilver
109
147
US
Thanks. I may stay with the 24" as my machine is smaller, and I'll be running a factory bumper. Looks like yours is the additional/aftermarket OEM one.
I appreciate the link.
Reactions: sharp
Oops! I miss that part, that makes a big difference.
Boomboom907
596
620
Washington
I have 2 52 inch bars.the one on the hood wobbles and I don't care for it
Sent from my Pixel XL using Tapatalk
Reactions: Eltobgi
USMCsilver
USMCsilver
109
147
US
The more I look, read, and see demos, it looks like I'll go with a 42" curved and mount it on the front of the top bar/roof.
Thanks again for all the input!
Reactions: sharp and Eltobgi
E
ebkoz
86
134
new jersey
I do not have any experience with atv/utv(s) but I'm considering relocating to Utah. I'm taking a trip out there at the end of the month to make the decision. That said if I move to Utah the first thing I will do is buy a P5 Limited Edition. I have been doing months of research (obsessed) about the mods I will install. Only speaking from research I don't see how a decent light bar could get seriously damaged by hitting small branches. I could not believe what these light bars can take in these manufactures torture tests! Also, It seems to me the roof mount produces a better light pattern. My plan would include a 52” curved combo roof mount, a 12” or 24” combo (that can change to amber for foul weather) mounted as low as possible (protected by the larger bumper/grill guard), a 12” wide angle flood for the rear that will use the backup alarm circuit and also a manual toggle. Maybe small corner lights and maybe some ground lighting tied into the interior lights.
Reactions: JTW and Smitty335
208,726
Go for it!
E
ebkoz
86
134
new jersey
I'm curious, has anyone experienced light bar damage from branches (I've seen brackets damaged)?
E
ebkoz
86
134
new jersey
Just wondering if there is a light/pattern loss mounting it so far back on the hood?
