P1000m5 Traveller II
2016 Honda Pioneer 1000-5 Deluxe
Up next was the winch, front bumper, and limb risers. The winch was a lot easier than I thought. Step one was to throw away the OEM instructions and do it my way.
D1dfa75ed329f7c258a50ff142c9977a
58e8f4dfa62b5b39c2c077ea1e337b92
9fed591d217e8599a06a4a13df5288ad
F09b565847ad99bcb1a53e9048debbbe
Up next with be the PDM and installation of the rest of the electrical accessories. Then it will be time to move to a lift, tires, skids, and who knows what else. This forum has cost me to much money trying to keep up with everyone, especially @JACKAL and @Whiskey.
Reactions: JTW and PioneerPete
283,350
@joeymt33 Looking good coming along nicely. I forsee a ROTM entry in your future.
Reactions: joeymt33
Just in case someone wanted to see more detail about the OEM PDM.
5a46de063bf6dc0ea9bca8dc95f213f8
It was nice having the pre-made switch panel, especially since I wanted to install a radio may run out of room. This setup was pre-wired to the back of the switch panel which made it easy.
Now for the Bussman PDM. Not sure how I will like this set up but I tried it anyway. It's installed on the backside of the glove box. If I had to access it often, I would not put it here. However, I don't plan on replacing fuses often do it may be ok. We will see, at least it helped keep under hood area somewhat clean.
C1bcdf1c49189285386d2ff5fb8ec114
You can see in this pic that I can still remove the cover and access the fuses
242faacb47603cc09c36fb5534ce9432
Here's a view from inside the glovebox.
8766112772ed4a2283d5bda3f86f9373
Reactions: Dp5hunter
Got around to mounting the light today. It's a little much, I'll admit. Well, I think it's a little much until it's dark and I turn it on. At idle, the volts are 13.6 so it's not too bad.
Then I got around to putting on a snorkel. I've been thinking of how I wanted to do this for a while. I've seen several different ways that other people have snorkeled their P1000 and they had good ideas but it just wasn't what I was looking for.
I didn't want to cut the fender because it would be a pain to change if I wanted to sell it one day and the new owner didn't want it. Also, I didn't want warranty issues. The last thing was I didn't want the noise inside the cab so I didn't want it in there.
So, I decided to go thru the hood. There are no other mods to the vehicle. I can remove the snorkel and put a new hood on and no one will ever know.
2b8721d35cd857a8d156d4806b35a8b6
I ended up powder coated the tube. I haven't had my powder coat out in a couple years.
32dcf070ade8a803fa368928c5366926
Several colors to choose from
C56aef3e26d577d6944be14c454717ba
0b0d16733912229c541e711765ad2a77
HondaTim
HondaTim
203
40
Looks good man I like it. Show some night pics in the woods when you get a chance. Also how hard is it to get the hood off with the light bar on?
Here's a couple more pics.
Ce0fb124cbb7b4a320385fe868a2f68e
From the driver seat
19b5fde0b3133d0ee6f746df276482af
It sounds meaner. I like it. Maybe it will help with the power when I put larger tires on.
Night pics will be coming in soon.
I cut the hole a little large in the hood and used some soft foam edging so it actually comes off easy. But that's after you remove the scoop at the top. As far as the light bar, it doesn't slow you down at all removing the hood.
Here's the clearance between the hood and light bar
Aa606155941ba387bb572dea049f1d0e
Reactions: Dp5hunter and Tot
Also mounted the horn, it's not wired up yet as I will need to make a new switch plate for it.
Ee056a1afb61a7c4c8ceace70648d304
I think it will be loud! I always find myself trying to get the attention of other riders in the group, now I can.
Ok, night pics requested? Here ya go
Stock LED head lights (they are bright!)
E2d68402e91aa3313138f46611d2decd
Stock high beams (they suck)
0956cecb6eb33c4c03707c5c5c15ab0c
Side lights
012d7183214e87de7c97073f3aa9ba31
Light bar only!
8ebaa54e7023e0e95139147c37f0b65c
Similar threads
Hometeam
Replies
Views
2K
Hometeam
