P1000m5 Traveller II
2016 Honda Pioneer 1000-5 Deluxe
Here's the pics for the front diff
OEM vent
96ae04194428f18086fd87edfd5ec593
Here it is installed
Eb97535f6a930a78212f82a42548e8f8
Another pic from a different angle
7d81e019c75c850da3e39d34950a80a0
The diffs had a smaller nipple sticking out so I had to reduce the tube size like this
31c0f35b76c67e6df1102c63368a1d32
And lastly, the bellow for the rear vent
OEM set up
1c57949bdd5752af62f4ccdda8a1de49
Bellow installed
758e30eeaaa96e7931a4f97f34ad9080
They seem to fit tight and I'll get to test it soon.
EDIT: after 800 miles, the bellow has caused the pinion seal to fail. I do not recommend this mod.
HondaTim
HondaTim
203
40
^^^^ I swear I'm not trying to sound like an idiot but...where is the air/heat suppose to go?
These bellows can expand and contract for the fluctuations in pressure due to heat build up. They are meant for jeeps so they should definitely be good for a pioneer.
HondaTim
HondaTim
203
40
Ok so when they expand where does the pressure go?
The pressure is what makes it expand. When the diff cools off, the pressure will reduce and pull the bellow back down.
Some people may not want to ford deep water but if you're 20 miles down a trail and can either cross a creek or turn around, these mods will allow you to have a piece of mind and keep going.
Reactions: JACKAL
283,353
The vent tubes don't vent heat so much as it does the expanding air, one of those billows carries the expandable volume of 25' of vent hose. The heat or hot expanding air goes into the billow slightly expanding it, as the machine cools off and air pressure drops the billow retracts. These differentials are small they only have so much volume to expand to begin with.
HondaTim
HondaTim
203
40
Thanks .... As I was researching about it a thread from the rzr forum popped up so I opened it and read it and they said they were all running the artic cat bellows that come stock on them because they are softer. And there are guys running them for the fuel tank vent also. It was said that if you run it up to the top of cab and put a small incision in the fold of the bellow that you will have no problem.
Thanks for the info about the Arctic cat.
As for the fuel tank, I raised the vent to about mid way up the back of the seat. I posted some pics a couple pages back in this thread.
HondaTim
HondaTim
203
40
Did you bellow it also or just put a filter on it?
No bellow or filter as of now. I would like to find a filter soon if I can think about it.
We use pneumatic exhaust filter at work which would be great for this application.
OEM did not use a filter and it was lower. At least I've got it moved higher, I'll have a filter soon.
N
Ned
241
183
West Kentucky
This pic shows how they are removable when I'm working around the acreage at home.
9b678409b3c6f3f0463239a6f7318750
I can remove the plastic rivets and the extension when I know I'll be using the dump bed. I can put the extension back one when riding for recreation for the day.
May I ask what material you used to create your flare extensions? I believe I will do the same to mine.
I bought some HDPE on Amazon. It is the same material that the fender flares are made out of.
Cf04baefeacf20fbab35938a396cbec3
I had a little time this evening to get a couple things done. First was the bed extender. Pretty straight forward install. This is a quality piece, very sturdy, easy to remove, and should add a little extra room.
3acf8c1c4d3bc4ced06519932bf03a9a
4034bb74d681934d8e9c2782e2f6ec00
6054d2d9effadbfea5d9228db7167b91
Similar threads
Hometeam
Replies
Views
2K
Hometeam
