P1000m5 Traveller II
2016 Honda Pioneer 1000-5 Deluxe
What does the vent lines do anyways that's on the diffs? I've put bellows on my old Polaris rzr no problems I guess that's what I'll do on the Honda.
Replace the vent line with a bellow. You'll no longer have a vent line.
The vent is to allow the expanding and contracting air to have a place to go instead of pushing a seal out.
As the diffs get hot, the air expands and needs to have a place to vent. When it cools back down, it draws air back in. The bellow will expand and collapse but it's still sealed so water or dust can't get in.
Also, when the diffs are hot and you drive thru deep water, the diff rapidly cools and it will draw in water if the vent in under water.
84ed91984446de840d9fb1b8ff810f22
Am I looking this up right? What exactly is it going to do to help vent lines?
That device is built to supply a burst of air like aiding in building s fire.
The bellow for a diff or tcase is to contain the air but not allow the case to build pressure or vacuum.
Reactions: Dp5hunter
HondaTim
HondaTim
203
40
So you would install that directly into the vent line? I need some pics of the install lol.
I'll get a pic soon when it arrives. I will remove the hose and place the bellow directly on the diff
HondaTim
HondaTim
203
40
So basically it's a check valve ... Only air can go out not in.
283,357
More of an expansion chamber, similar but not exactly like the extra tank that hold fluid for your radiator. It seals the system, where air pressure goes in and out of the billow instead of water into the vent line.
HondaTim
HondaTim
203
40
So would this system be more safely...then compared to just running the vent line longer to the top of the cage? Thanks for the patience.
283,357
Theoretically yes because it would be a closed system, whereas a hose of any length still has an open end providing an opportunity for contamination of the fluids.
HondaTim
HondaTim
203
40
Ahhh
F
Fullthrottle
164
84
I guess I'll be add another task to the to-do list. The sub trans will need to be snorkeled as well.
Here's the vent tube which goes into the frame just below the seat
975be47d0e91c540aedf9cad6fd2464c
Another shot
E3929615559d5e0c078b6879eff4bf0f
Here's what happens when you get oil in the sub trans. Look down the dip stick hole
098858d59d670c897dde98d8c64df5b1
I'm glad I have a routine of checking EVERYTHING after every long ride. I don't do that every day around home but I will after all day events.
Where did it get water in shouldn't it be sealed if it vents into frame or is the frame full of water.
The frame ends are not capped. Water can enter there.
The WetSounds finally came in. I'm so glad that I got the 20" model, this thing is loud! It's not wired to the head unit yet, just been using it on Bluetooth. Here's some pics of the mounting location. I chose to mount it to the roof.
D631cce2e505f899fbd97722a6572641
E621bb833cd38cd7a9bf34133722bb04
94f74355c3efdc15b6cd6136315b52ea
I've got some rubber backed ~3" diameter washers on the roof. This thing is rock solid. I was a a little weary of this setup but it doesn't move at all.
Joe
Hometeam
Hometeam
1,047
4,434
Normal, IL
Do you have a picture of the top side? I have the same wetsounds speaker sitting the box still. I really like that location but it does make me wonder how it will hold up slamming around at an off-road park.
I'll get a picture of the top side tomorrow. I can tell you that it is very sturdy. I can barely budge it.
For me, gets too loud when turned up. This is a quality speaker with the weight to back it up. It feels like I'm holding bricks when I pick it up.
I have no regrets with it. It does not distort when maxed out either.
Reactions: cruddy0815
Tflynn
Tflynn
Not a liberal
2,501
3,834
Northern California
Hey Joe in regards to the forward arched a-arms, do you know where you'll get them? I been keeping an eye out for some to put on my 700, even emailed superatv. They said they might have something out by spring. Did you find them somewhere else?
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
I talked to @HondaProKevin today... it sounds like Outcast Fabworks, Highlifter, and Catvos all have forward arched arms in the works. Availability rumors are late January from Outcast, and mid February from Highlifter. Not sure about Catvos...
Reactions: Tot and Tflynn
It looks like HL and Catvos have them for the p1000 in a couple months. There's a thread about the Catvos A-arms with pics of them installed on two pioneers.
I think outcast has them for a p700. There's a pic of the p700 with them installed some where.
Reactions: Tflynn
I got the bellows installed today.
Here's what they look like.
2ce6e915e53ff2ec62e1f369e3cac25f
Here's the subtrans with OEM vent removed
A7c3386cae4bde5b8dd2c005728c069c
Here's the bellow installed
Bbb09742cfd3eaa44d5463ef639b52c5
I used a spring clip like pictured below
A34ea294dd4bacc9ea0c3cf35313c7d1
Similar threads
Hometeam
Replies
Views
2K
Hometeam
