P1000m5 Traveller II
2016 Honda Pioneer 1000-5 Deluxe
@joeymt33 Very nice, like how you have the isolator tucked away while integrating a battery strap and ground for the second battery. But what is the black box between the radiator tank and the intake pre filter cover? Is that your PDM or winch relay?
That is the OEM PDM. Because I want to install a radio, I would run out of room for switches where the warning placard is. Therefore, I chose to use the OEM switch panel and PDM. It's a little pricey but the switch panel was precut and included a volt meter. Also, all the wiring was included with relays and fuses. I only had to insert the switches and connect accessories to the PDM. I have a Bussman PDM like you have for my remaining accessories.
In this picture you can see the OEM switch plate. Also you can see the panel for the radio and other switches. I could have crammed them all in next to the radio but I prefer to have some room between switches so they can be switched accurately while the vehicle is bouncing around. Also, when wearing gloves, the extra distance between the switches help.
6038218ab91f7fcec8be8bbd2b77fa6e
Not saying it's for everyone, it's just my preference.
More on the battery strap. It's just a piece of mild steel I bent to the contour of the battery. It's held by one screw that goes into the metal brace just behind the battery. On the other side, I cut a rectangle hole and slid the piece in. There's not any metal for a screw to be used on both sides.
9254e8ca0da4e5a8df1bd0eda1978aa7
Reactions: Dp5hunter
Got the radio and three more switches installed today. I had to stop there because I'm waiting on the PDM and USB port for the last switch hole. Also, I'm waiting on the WetSounds Ultra 6 to finish out the stereo.
I cut a hole in the dash and left enough plastic to attach the panel too.
D80c1e050d4ea21697304d6ba01082fc
Here's the panel cut and ready
59db478e546325bb0e1ca92d877b9332
I went ahead and started wiring what I could like the hots and grounds for the back lighting
05b9ae9317ff36798c761d85e2e174fe
Here it is installed for now.
2e9f654030d8b5519ea712346080676b
N
Ned
241
183
West Kentucky
Looking at your rear fender flares, I cannot quite see what you had to cut. I have them also and didn't have to cut anything on the rears. I am at work and can't look at mine now but I'm gonna have to look over the area that you had to cut and see what maybe I am missing....I seem to be doing that more lately. May I ask about what you are using for interior lights?
And....with the OEM PDM in place already, I can't wait to see what you are going to do with the Bussman. I still haven't placed mine, although I have changed the type of isolator I plan on using that doesn't require a connection to an ignition source, and it's much shorter in height, hopefully affording more placement options. Placement of your front cubes was very creative...and the pushpins for your switchplate.
Reactions: joeymt33
Kenjones21
Kenjones21
165
107
Central Louisiana
I see you have a winch In and Out switch and a winch power switch, On the rocker (In & out ) switch does is stay in the in or out position till you turn it off or does it just go in or out as long as you pushing it one way ? Also if you don't mind me asking whats the point of having the winch power switch?
allgm1
allgm1
1,049
1,485
New Hampshire
the in/out switch is probably momentary so when you let off the switch the winch stops. I would assume that the winch power switch, when turned off would disable the in/out switch in case of accidental contact.
Reactions: joeymt33
There's several topics here and I'll break it up and comment on one at a time.
1: fender flares. I'll post another pic of the cut out place. It's at the very back of the rear flares. There's was already a cut out in the correct location but it had to be enlarged quite a bit.
90ffd981dfd0cde087d1996be02b08dc
2: the interior lights are pictured below. They have been very durable in my experience. I've got them on my truck rear bumper as well used for reverse aux lights. They are alway out in be weather and never failed. They are super bright!
F12b34564c002ca9a1b5ee14858212ad
3: space is tight under the hood. Not sure where I will place the PDM yet either.
4: thanks for the compliment on the lights and plastic rivets for the switch/radio panel.
The winch In/Out switch is momentary style so no need to turn it off. Just release it.
The winch power switch lets me lock out the power so that I won't accidentally pull the cable too tight or release it. It also lessens the chance my sons will activate it.
More on the MudBuster fender flares. I had a chance to test them out. I had some problems with mud to show for evidence.
First pic, you can see the front fenders collected a lot. The faster you go, the more the front tires sling it straight up and then it's carried back on the fenders and windshield.
Ec1c0d243f1a21d74a9dedf834f998e3
Second pic and third pic, his shows how much the rear tires sling up just behind the flares. It's get everywhere.
493aec5189f5251f8c9c3b39a433a049
0e91a0b60c08d2b24697e806b04ef879
My solution for the rear is show in these pics.
0482f41f649852f6f4a805c8e58e4e03
721efb50fa02dc854656e60b8139c3f5
4de03a5249bcb7f556bb29a016afbe1d
This pic shows how they are removable when I'm working around the acreage at home.
9b678409b3c6f3f0463239a6f7318750
I can remove the plastic rivets and the extension when I know I'll be using the dump bed. I can put the extension back one when riding for recreation for the day.
I guess I'll be add another task to the to-do list. The sub trans will need to be snorkeled as well.
Here's the vent tube which goes into the frame just below the seat
975be47d0e91c540aedf9cad6fd2464c
Another shot
E3929615559d5e0c078b6879eff4bf0f
Here's what happens when you get water in the sub trans. Look down the dip stick hole
098858d59d670c897dde98d8c64df5b1
I'm glad I have a routine of checking EVERYTHING after every long ride. I don't do that every day around home but I will after all day events.
The good news is, the only time I drove thru deep water was just before I put it on the trailer. After that, we came home. I'm sure this is where that water got in there. We found a deep water hole with a hard bottom that we used for cleaning the mud out of the skid plates just before heading out.
I'll go buy some cheap oil and change it two or three times and then refill with Honda recommended oil. Should be no problem at all. I've seen this several times on my foreman 450s engine oil and its 13 years old now with no issues or repairs.
GO HONDA!
I ordered these bellows for the diffs and the sub trans. I hope they work out good.
7db49002cf10d35845918fc21b444f16
Reactions: Hondasxs
Kenjones21
Kenjones21
165
107
Central Louisiana
Thanks for all your help , I think I've got everything I need ordered so hopefully within next week or so I will get it all hooked up
Reactions: joeymt33
I would say it's time for some protection for the undercarriage and A-arms.
A7848da279df3ec9d8ef6ee0fb1d86e5
6f7675fca8245fbdec8608baa715e09b
87a47ef08e559c20e4f1113a2872a2a1
I'm doing the bellows on the subtrans and both diffs. The fuel tank need to be vented with an open ended tube so I'll leave that the way I have it extended.
HivoltageHonda
HivoltageHonda
374
367
Hernando, MS
What does the vent lines do anyways that's on the diffs? I've put bellows on my old Polaris rzr no problems I guess that's what I'll do on the Honda.
HondaTim
HondaTim
203
40
84ed91984446de840d9fb1b8ff810f22
Am I looking this up right? What exactly is it going to do to help vent lines?
Similar threads
Hometeam
Replies
Views
2K
Hometeam
