P1000m5 Light Bar Mounts, who wants one.
T
taylorman
167
97
Lafayette La
So I bought a few pieces of aluminum angle to make myself a lightbar mount. They ended up being so easy to make that I made quite a few. If anybody wants one drop me a $10 for shipping and I will mail it to you.
Reactions: Samiam1286
T
taylorman
167
97
Lafayette La
Pics are in Taylormans build post
T
taylorman
167
97
Lafayette La
IMG 0924
IMG 0923
Markbama
30
12
Millbrook AL
I would like 4 of them if you have that many available...message me on how to send the cash...
T
taylorman
167
97
Lafayette La
This is how they are installed. I use 1/2" x 1 3/4 hex bolt and a nylon locknuts. I use a thin 9/16 nut as a spacer.5482727c1407fda3012fa06a8354a8c7
Reactions: Mtnmonkey
T
taylorman
167
97
Lafayette La
Great thanks. FYI. It should fit a 50" curved light bar perfect.
TAW
TAW
73
88
Texas
Have you mounted the 50" curved light bar using this set up yet ? just curious if it does fit because I'm getting ready to order the light and don't want to have to return it. I'd appreciate any info thanks
O
oldskoolbuckets
42
25
Colorado Springs, CO
I have not because I cannot decide on which light to get. Can't choose between Osram or Cree. I was also looking at probably trying a 52" light bar and turn the brackets around so the tabs face inward.
TAW
TAW
73
88
Texas
Ok thanks I took some measurements looks like it should fit ordered light bar today I'll let you know how it works out.
TAW
TAW
73
88
Texas
IMG 2718
Just mounted my light bar tonight these mounts would work better with a straight light bar had to shim mine a little but still pretty happy with the install
Reactions: sharp
TAW
TAW
73
88
Texas
SLDX from amazon came with two cube lights 50" light bar and two wiring harnesses $119 China cheap hope they hold up couldn't drop a bunch of cash on better ones after dropping 20k for my Honda and having to purchase a new trailer
TAW
TAW
73
88
Texas
The inside half of the mounting bracket the light manufacturer didn't account for the curve so the brackets toe in slightly
T
taylorman
167
97
Lafayette La
What did you use to shim it?
quickfish
quickfish
36
46
Kent, WA
Thanks for the mounts, they saved me a ton of time lining up and drilling the holes
