P1000 Little Buddy Heater Mount
Jankyeye
Jankyeye
883
4,196
Tampa, Fl.
Sorry its taken awhile as I've been hunting and using the heater. I finally got some pics. I'm usually OCD and build things that work and LOOK GOOD. This was actually a thrown together early morning project that has worked so well I haven't messed with it. It just sits in the compartment below the warning label (switch panel) and sits on the seat. I ended up putting a 2x4 on the end to have it sit level. I then just screwed a 2x4 upright to attach the heater too. It makes it kind of tough getting to the switches but I usually just tell my passenger to change the radio station. I also was able to mount a horizontal fan on the top to circulate the air. It works really well, but after hunting season I might upgrade it so it LOOKS better.
View attachment 363845 View attachment 363846 View attachment 363847
What sort of fan is that? Is it 12v?
tjoreo
tjoreo
1,032
1,992
Southern Idaho
It is 12 volt. I didn't know how it would actually work, but it has worked very well for the last 3 winters. Like I said, the reason I like to use my Buddy heater vs putting a built in heater in my rig, is that I can run the heater without my pioneer running. And this little fan just makes it that much better. I ended up 3d printing some mounts that the fan just slides into so I can take it off if I want.
Seanflyguy
Seanflyguy
34
Hudson
My Mr Buddy solution for supplemental heat- works well.
0B4DFFB2 33A4 426F B8CB 6A1C347B44C0 A79B4B83 32D5 46D4 AB59 9BB9DBC14422
Seanflyguy
Seanflyguy
34
Hudson
My simple solution, Mr Buddy heater front seat using 2 straps keeps it in place and provides more than enough heat in N WIS
surrounding seat does not get hot. Mr Heater makes a good product-
58247781 104C 41EE A896 5315DE1C1078 6B730F99 6AB0 4A94 82BE 8F2C6F009014
Buggyman
Buggyman
47,989
376,372
ne. ohio
View attachment 366632 View attachment 366633
like the Mr. Heater just picked up a second Big Buddy heater at Tractor Supply for $99.00. last year they were almost 200
tjoreo
tjoreo
1,032
1,992
Southern Idaho
I saw yesterday that our local Costco had the Little Buddy Heater with a propane hose and filter for under $100. If I remember right it was actually on sale for $79. I really thought about grabing another one but I figured my wife would say that I don't need 3 of them. It has really worked well for my rig.
