P1000 Looking for Wheels in all the Wrong Places
PJon
PJon
797
3,237
Arizona
One final question:
I found these and am ready to pull the trigger.
As far as you know, I have found the correct wheel, even though the website says that it will not fit my vehicle when I put in Honda Pioneer 1000-5. Correct?
I run 14" 5-2 all the way around and have no rubbing. A day or two ago I responded to someone else on the forum who was having problems with his 14" 5-2's with 28" tires. He stated that that the dealer installed them with 1" spacers and he had severe rubbing. When you run a 14" 4-3 offset, during a turn, the outer edge of the tire will be closer to the body due to geometry.
Reactions: Lady01 and Isaiah
O
Olive2016
7
24
Arizona
IMPORTANT NOTE: I purchased the ITP Delta Steel Wheels that I mentioned in my post above. THEY DID NOT FIT. The bolt pattern was acceptable, but THE BOLT HOLES WERE WAY TOO SMALL. The Honda lugs did not fit through the holes.
I thought about drilling out the holes to accommodate the larger Honda lugs, but the center hole in the wheel was too close to the lug holes and that would have left just a sliver of metal between the lug holes and the large center hole.
So, the moral of the story is that the ITP Delta Steel Wheel 14X7 that says Compatable with 11-19 CAN-AM COM1000XT will not fit a Honda Pioneer 1000.
Still looking for wheels in all the wrong places.
O
Olive2016
7
24
Arizona
Fit perfectly!
If you are looking to put new shoes on your Honda 1000-5 but don't want to have to do a lift kit or to use spacers, here's what I did and it worked perfectly:
From Ebay:
Wheels
From Amazon:
Tensor Regulators
This combo works perfectly!
No longer looking for wheels in all the wrong places!
TripleB
TripleB
16,373
148,239
Caryville, Tennessee
Fit perfectly!
From Ebay:
From Amazon:
How wide is your machine in the front and rear now?
Reactions: Lady01 and ChadD
Sr56
97
289
53
Murfreesboro
Fit perfectly!
From Ebay:
From Amazon:
@Olive -please post a picture when you have them mounted.
Reactions: Lady01
