P700 Looks like I am shopping for a new rim
L
LCK_Boater
39
39
Lebanon, OH
Hit a rock under some leaves today and ruined a front rim. Was planning on bigger tires and rims but was going to wait till the factory tires were shot. Guess I will be shopping sooner. 138593AD 3441 4887 8D79 BC05FDCD6791
208,717
Are there certain rims that hold up better to rocks?
Nope! You need better tires with stiff side walls even with lower air pressures. The rims are a whole different story, for some reason Honda runs a different wheel offset front and rear, so if you get the same off set front and rear on your new rims, the front will be 2 inches wider than the back. You can correct this two different ways if you want to, install 1 inch wheel spacers on both sides of the rear or order different wheel off sets for front and rear, an example on mine, 6 + 1 for the front, 5 + 2 for the back. I've got stock width front and back and there the same width. But I ride tight trails and didn't want anything wider than stock.
L
LCK_Boater
39
39
Lebanon, OH
Thanks! A lot of trails I ride are tight also, squeezing between trees. I will need to stay at stock width for sure.
L
LCK_Boater
39
39
Lebanon, OH
Is there a reason to go to a larger rim size? I see some people doing 14" rims instead of the 12's that are standard. I think for sure I want to go to 27" tires as I could use the extra ground clearance.
L
LCK_Boater
39
39
Lebanon, OH
OK, I think I am going with Tusk Terrabites for my tire. 27x9 - 12 for the front, 27x11-12 for the rears. HD3 wheels with 5+2 offset all the way around. That is what the package builder on Rocky Mountain put together. Am I understanding correctly that the 5+2 in the front will make it a little wider? Would it be same width front and back then? Any concerns with that?
Backwoods
Backwoods
34,417
350,416
Douglasville ga
Yes it will be slightly wider I have the 5+2 offset I like the stance it gives it. If you want to even it out you can put a spacer on the rear wheels.
jwfirebird
jwfirebird
927
1,446
western ny
not much difference in 14 and 12 but some tires give a better ride with the 12 being more rubber, 14 could handle better. but a lot of the bigger sized tires don't come in 12
Tflynn
Tflynn
Not a liberal
2,501
3,831
Northern California
Sounds like you’ve probably already ordered the new set but (and I know this sounds pretty sketchy) many times when that happens to steel wheels you can beat them right back out with a hammer. Is it the right way? No. Will the wheel be true? No, but close. I bring it up because it could get you out of a jam on the trail. I’ve done this “repair” a few times with good results getting tubeless tires to seat and reseal.
Reactions: Backwoods
Tramguage1
Tramguage1
Texan
7,346
29,399
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I have 2 rear 700 steel rims i will part with for shipping cost!!!!!!!
Tramguage1
Tramguage1
Texan
7,346
29,399
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
If he’s not interested I would be what’s the price shipped to Nebraska and how would like to be paid .
Will do,PM me you delivery address. Ill check on shipping cost.
Lets give him first chance
L
LCK_Boater
39
39
Lebanon, OH
New wheels and tires are on. Loving the look, now just need a chance to test them out. 27 Tusk Terrabites with Tusk wheels.
Also added a steel tailgate with spare tire carrier from JEI. Going to use the old front as a spare. while it is is only a 25" tire it will be good enough to get me back home if I blow one out.
