Talking about loose doors. Has anyone tried to lock the hinge bushing into the door. The bushings just float around in the door and are eventually going to wear the door.
Best way I found to fix that area is to pull them out spray expanding foam all around in there and replace them. Way better then just glueing them in. You're doors will be much stronger
