P700 LOST MY KEYS
V
VADER
0
knox,ky
GUYS I HAVE MISPLACED THE KEYS TO MY PIONEER...I FORGOT TO WRITE THE KEY CODE DOWN...IS THEIR ANYTHING ELSE I CAN DO TO FIGURE IT OUT OR GET A NEW KEY WITHOUT REPLACING THE KEY SWITCH?
I think the dealer can get the key with the VIN#
Signature:
QUOTE by Eltobgi, Honda...Strong enough for the Farm!...Dependable enough for everything else!
Reactions: CumminsPusher
Lynn1130
Lynn1130
126
171
Phoenix, AZ
I think if you look at your owner's manual it has a diagram showing where the VIN, Engine Number and Key Number are stamped on the frame.
OK, my mistake. I looked at the book and it has VIN, Engine and Color but you can get the key number with the VIN if you call Honda or check with a dealer. They should be able to get it. They are going to need some proof of ownership I would guess before they give you the key number.
Key number should be on the side of the ignition switch. 6 or 7 digit number, key cutter will need last 3 digits. Should be a letter then 2 numbers. A/B/C/D and 00-99. dealers cannot get key codes with VINS, unless the dealer you bought it from records it down on their major unit inventory like we do.
Reactions: Tflynn
