P500 LOWEST AIR PRESSURE ON 28" TIRES
Steve00
Steve00
64
91
Florida
What is the lowest air pressure I can get away with on 28" tires were 12" rims without the bead locks? Right now I got them at 5 PSI
  • Wow
Reactions: JenElio and J80
Markdale
Markdale
Kitchener
I ran at 3 psi for a while, the bumps were better but steering was hard and handling was crap
IMG 2382
Backwoods
Backwoods
32,466
333,100
Douglasville ga
Be careful I have had a front tire break the bead turning with 5 PSI.
P
pappyo
593
2,380
Things to consider when running low tire pressure. ( 5 lbs.)
Sidewall ply rating ( 6 or 8 being min )
Riding style ( slow or aggressive)
How far off road you' ll travel ( especially if alone )
For slow speed crawling you should be able to get away with 5#. ( Sudden drops , impact or push to hard against object ) could give greaf.
Faster & more aggressive riding the unseen surprise sudden hard impact ( rock / hole / log ) HAS Caused Many of Bead to Brake & Side Wall to Cut.
Going down the trail at 10mph - 20mph & up in a 1000# SXS plus gear driver ----impact generates ( Tons NOT pounds) 5 # tire pressure would not take much of that type of impact.
Hope this has helped & not too long.
ITP MUDLITE XTR 6PLY 27X912 FT.--27X11X12 REAR ( Slimed )
Depending on load --6.5 lbs to 8.0 lbs. Gives decent ride & good traction ( W.E. Shocks with heavy springs )
SLIME , AIRCOMPRESSOR & Tire Repair Kit have saved my Tush more than 1 time. ( no spare ) usually alone 12 -- 15 miles off road.
Steve00
Steve00
64
91
Florida
Thanks everyone. I'll go with 7lbs on all 4 there 28" on 12 inch wheels. That should be good and safe for what I need. I don't drive too aggressive
Reactions: JenElio
Peter_72
Peter_72
792
6,526
Louisiana
It really depends on the tire, the thicker the tire the less psi it will need. The tire on the stump is 28” and was flat for 24 miles and never had a problem
CAABC16E D6CA 4259 BD96 DE43FBF03BB3
