Things to consider when running low tire pressure. ( 5 lbs.)
Sidewall ply rating ( 6 or 8 being min )
Riding style ( slow or aggressive)
How far off road you' ll travel ( especially if alone )
For slow speed crawling you should be able to get away with 5#. ( Sudden drops , impact or push to hard against object ) could give greaf.
Faster & more aggressive riding the unseen surprise sudden hard impact ( rock / hole / log ) HAS Caused Many of Bead to Brake & Side Wall to Cut.
Going down the trail at 10mph - 20mph & up in a 1000# SXS plus gear driver ----impact generates ( Tons NOT pounds) 5 # tire pressure would not take much of that type of impact.
Hope this has helped & not too long.
ITP MUDLITE XTR 6PLY 27X912 FT.--27X11X12 REAR ( Slimed )
Depending on load --6.5 lbs to 8.0 lbs. Gives decent ride & good traction ( W.E. Shocks with heavy springs )
SLIME , AIRCOMPRESSOR & Tire Repair Kit have saved my Tush more than 1 time. ( no spare ) usually alone 12 -- 15 miles off road.
