My main 30 amp fuse will blow as soon as the key is the turned on. I have check several components, i can unplug the ECU, replace the fuse, plug the ECU back in and the will start and run fine. It will not shift into any gear? When you turn the unit off and try to restart the fuse will blow again.
I have a new battery installed and a new ECU on order. Has anyone had this similar issue, i was thinking ground but haven't found a issue.
