P1000 Maxxis Carnivores
Honda1000-5
Honda1000-5
216
342
New Brunswick Canada
An old question but: Can I use 30x10-14 Carnivores on my stock P1000-5,if they rub will it cause much damage?
Thank you
Reactions: Isaiah
Russ989
Russ989
22,645
147,291
They will rub. What damage it causes depends on how you intend to ride. I'd go with a 28x10-14 if you intend to keep stock A-arms.
I 2nd this, if you’re going bigger than 28s without changing a-arms you’ll have trouble.
Scamih
303
813
Marshall Illinois
How do you like the Carnivores? In thinking about buying a set?
Reactions: Isaiah
Honda1000-5
Honda1000-5
216
342
Only about 200 miles on them, but I like them. Good all-terrain tire, steering is more precise and the ride is good. Already I've been in a deep mud hole, very tough rocky trails and long steep gravel hills with no problem. I also travel a fair bit of blacktop. Still not sure of what inflation pressure to use and have them at the Honda Manual 14lb rear and 13lb front, may take them down a little.
Reactions: Isaiah
Scamih
303
813
Marshall Illinois
I’m curious if they last long on the blacktop. How is road noise compared to stock tires?
Reactions: Isaiah
Honda1000-5
Honda1000-5
216
342
Less and cornering is more controlled.I will say my first choice was for Bear Claw HTR's or AMS M1 Evils but couldn't get them here in NB, Canada. Happy with the Carnivores though.
Reactions: Isaiah
