F
Welcome to the club.
A flap for the purple area is not included with any Talon.
The part you mention is in red.
There are some people making one tho. Maybe someone can give a link?View attachment 171294
Maybe.. IDK.I thought people were buying the left side and attaching it to cover the hole.
Yep, Just buy the Honda piece, flip it over and it fits perfectly on the other side.
Yep took it off, flipped over. The fasteners are a mirror image of the drivers side. It will over lap in the middle.plan to order one. I want to mount a fuse block behind it. Then to access it just remove the rubber flap.Yep, Just buy the Honda piece, flip it over and it fits perfectly on the other side.
Thanks for the part#. Dealer couldn't find it. Ordered it today. $5.08If you are referring to the rubber flap that is part # 61250-HL6-A00 and theres isnt one for the right side from the factory.
The part you are listing appears to be present from the picture you provided, that part is actually the plastic inner fender. The 2 holes in the first picture that touch the frame bar are actually in the part # you listed.
Use Honda techs part #. Ordered today. $5.08. 7should have it Friday.I tried to order a left side flap to install on the right side but it was backordered so I bought the firewall shield (available without the mud flaps) linked above. Installation was easy and it covers a little more area than the stock one. Thumbs up.
