P1000 Moving on.... winch time.
ACfixer
ACfixer
Global Warming Enthusiast
218
840
N/E Tennessee
Since I am doing all the electrical stuff first, let's get the winch out of the way. Let's hear it folks, just buy the winch from the club store I assume...
Viper elite 5000 widespool and a mounting plate? Any reason to choose otherwise? Anything else I will need?
Gabbas
Gabbas
280
701
Humboldt, Iowa
That's what I have. Works great.
Sent from my Pixel 4 using Tapatalk
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
The club store is a great option for sure. But,..... if you're looking for something else i'd recommend
going here -> Offroad Accessories | Montana Jack's Outpost, Warn winches/Snoplows – Montana Jacks Outpost
Ask for Scott and tell him I sent ya. They have the best WARN prices in the country and excellent service.
Can't go wrong with either place you choose.
I did the Warn 4500 vrx with wireless remote and it was excellent.
Russ989
Russ989
22,642
147,257
Viper elite widespool has my vote. I’ve bought 2 of them (700-4 and 1000-5) they’ve worked great.
ACfixer
ACfixer
218
840
N/E Tennessee
Okay I ordered the Viper elite 6000 widespool based on the fact the 5,000 was showing low stock. Wasn't that much more money so I'm good with it.
ACfixer
ACfixer
218
840
N/E Tennessee
Okay, a couple things... the mount plate that comes with this elite widespool 6000 bolts to the vertical frame tubes via 4 u-bolts.
First off, the holes in the mounting plate were not big enough to accept the mounting bolts. Had to drill two of them to 25/64 and then it was okay. Next, the plate was too big to fit between a part of the welded frame member up above and the diff mounting bracket below. I had a couple choices.
1. Mount it kinda crooked with the mounting plate hitting the diff bracket. Might have been okay, but hokey IMO.
2. Grind off part of the frame upstairs or a little off the diff bracket. Yeah, no thanks.
3. Grind a couple notches in the mounting plate. This seemed like the lesser evil of course and it appears to work okay.
Here you can see where I ground a bit off the plate.
Honda 4
One of the terminals for the cables is really close up against the plastic bumper shroud. I think it will clear okay. I'll get a pic of that soon here.
Dirtstiffs-1000
Dirtstiffs-1000
1,672
6,082
hondasxs.com
You will not regret the widespool #6000.
I have one but had no issue with mount plate.
As I remember the plate was a special order seperate from the plate that came with the winch. MA 11818 I think.
Took longest to get bumper off and on.
No wiring issues.
Dash mounted switch and remote work great.
MA11818 01 800x
ACfixer
ACfixer
218
840
N/E Tennessee
I have the same mounting plate. Just needed a tad of relief as you can see in my pic, I could have probably just tightened it down... but I like the way it sits a little better now. All good. And two of the screw holes needed a bit of enlargement, the plate mounted to the winch base with two different size bolts.
The power leads are really long, I am heading to Advance Auto to get some terminals so I can cut them down a bit.
