P1000 My New P1K5 in the shop electrical issues.
Sjc3081
Sjc3081
263
442
Wappinger NY
My Pioneer is having electrical issues. The 2wd, turf, 4wd and 4wd lock icons are not indicating properly. She enters each drive mode when selected but the icons on the dash just show turf mode only. Returned to dealer only the next day after initial pickup. The dealer is going back and forth with Honda trying to find the Gremlin. The swapped the pod and the ecu from known good machines with negative results. All the grounds are good and tested. What do you guys think.
Reactions: sharp
WOT-Outdoors
WOT-Outdoors
46
83
Rochester NY
I have the same exact problem
Sent from my XT1635-01 using Tapatalk
Reactions: sharp
WOT-Outdoors
WOT-Outdoors
46
83
Rochester NY
I adjusted the turf mode selector but it still didn't fix the problem. Keep me posted on what you find out so I can inform my dealer
Reactions: sharp
Sjc3081
Sjc3081
263
442
Wappinger NY
I will I’ll. Get a printout of the repairs when made and I’ll forward it to you. Did you bring it back to the dealer like I did? My machine was transferred from Rusty Palmer, was yours?
Reactions: sharp
WOT-Outdoors
WOT-Outdoors
46
83
Rochester NY
I have yet to take it to my dealer. Im not sure where mine come from
Sjc3081
Sjc3081
263
442
Wappinger NY
Update, They are replacing the wiring harness, Honda suspects this is the issue.
WOT-Outdoors
WOT-Outdoors
46
83
Rochester NY
Oh boy! I hope they are right because that can't be easy today.
dilligaff82
157
315
New Hampshire
Mine has been like that since it was new. Got sick of bringing it back to the dealer. Hope they can get yours figured out!
Edit to add: actually when it was new, it worked properly. When it went in for the first service I had them adjust the shift cables because it was sticking in 2wd when I’d try to go to turf mode. Ever since then it’s shifted modes properly, but gives no indication on the dash.
I’ve poked around at it myself a few times and tried playing with adjustments to no avail.
WOT-Outdoors
WOT-Outdoors
46
83
Rochester NY
Maybe I'll bust out the manual and do some checks on the electrical indicator switches. Ecu's and wireing harnesses seem a bit much
Sjc3081
Sjc3081
263
442
Wappinger NY
The dealer went though many tests of grounds and sensors as directed by Honda. The final repair is the harness.
I’m going to try to get a extended warranty, extra 48 months heavily discounted or free. I’m out of service for six days now.
Reactions: WOT-Outdoors
WOT-Outdoors
WOT-Outdoors
46
83
Rochester NY
Did you just buy it? Hondas come with a 1 yr warranty. I bought a demo model so I get 2 yrs
T
tbaker
365
637
NW. Georgia
So this unit was brand new if it were me I would ask for another machine instead of asking for an extended warranty since it’s just been 5 days since you bought it was it a 2019 model
HondaTech
I'm assuming they checked all the sensors in the diffs as well. I've seen one that had a misaligned piece in the diff and wasnt triggering the sensor l.
Sjc3081
Sjc3081
263
442
Wappinger NY
16 days at the dealer, harness replaced, it did not fix the issue. Now Honda is overnighting a new rear differential to the dealer. I called Honda Customer service in California. I told them I want a new machine. No was the answer, Honda said they said they have reasonable time to fix machine. What is reasonable I asked, he wouldn’t answer.
Neohio
Neohio
Beast of the East
14,587
73,832
Painesville Ohio
16 days is nothing. My dealer is so inept, it took them 3 weeks to do the clutch update properly.
Reactions: JTW
Sjc3081
Sjc3081
263
442
Wappinger NY
B17BAF39 06E0 4290 B602 7A9C8D517BEE
This is the current state of my machine
T
tbaker
365
637
NW. Georgia
So do they think the rear differential is the problem and it sucks that every time you ride it’s going to be in the back of your mind is this piece of s*** going to mess up again sorry you are have these problems
